Can I adapt an LNB ?
Thread Tools Display Modes
Old 15-11-2007   #1
koansrc's Avatar
My System: CM 3.0m @ 28.2 w PACE
Hello all,
I have a cheapo lnb 0.6 f/d and I would like to convert it to 0.4 f/d and try it on a prime focus dish. Can it be done ?
I assume I must shorten the length of the feed but it would be nice if someone could confirm this before I actually start hacking away at the lnb
Of course the next question is "by how much"
koansrc is offline   Reply With Quote
Old 15-11-2007   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb
LNB's might not look it but are precision engineered bit of kit - if you start hacking bits off its not going to work properly at all......
__________________
Analogue forever!
Old 15-11-2007   #3
koansrc's Avatar
yup I realize that much !
But this is something I've got to try. I just can't ignore the voices inside my head .!.
but maybe I won't use the axe or the chainsaw after all. More like a precission cut with a fine blade. Sooooo, do I shorten in order to reduce the f/d ?
Old 15-11-2007   #4
jimbo's Avatar
My System: Sky HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
I think a 0.2 would be cheaper than a fine blade. So have one waiting in the wings when your experiment fails. Oooppps I meant if it does.
__________________
Jimbo
jimbo is online now   Reply With Quote
Old 15-11-2007   #5
koansrc's Avatar
Hey jimbo, I guess you share Analoguesat's pessimism ( to put it mildly ) and since I believe in "waste not want not" I'll reconsider !
But I like your use of the word "experiment" !! Great choice. Brings Braniac and exploding caravans to mind somehow. But ... what's a 0.2 ?
Old 15-11-2007   #6
Site administrator
0.2 is the dB noise level on the lnb
By all means hack some bits off --> sorry do some careful re-engineering on the lnb --> but make sure you have a replacement lnb to hand "just in case"
Please report back one way or another.
And if you re-engineer it by dropping a caravan onto it I want to see the video on Youtube!
__________________
Analogue forever!
Old 15-11-2007   #7
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Perhaps Jimbo is talking about a F/D of 0.2 not its noise figure?
Confused though because you wanted a 0.4 F/D anyway.
Robbo71 is offline   Reply With Quote
Old 15-11-2007   #8
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Simply rip the cover off the front of the lnb, measure the internal diameter of the feed horn, wedge a bit of (the same size) very thin pipe in the end, and cover the protruding pipe with tin foil. This will change the illumination to that equivalent to one with a lower F/D.
Mess around with the length of protrusion to give max signal to noise.
You will lose a bit due to the thickness of the pipe, for best results the bore should be constant and the same size as the original LNB.
Good Luck.
Yeee Haaaaa!
Low Profile is offline   Reply With Quote
Old 15-11-2007   #9
My System: 2.3m p-Focus Dish, Invercom LNB w/Scaler ring, Manhatton 550 receiver
Shortening the LNB will not make it more suitable for a smaller F/D ratio, for that you need to change the angle of the "flare" bit. What you could try is -make a skirt (I'd guess at 10mm depth) to fit around the existing flared end of the LNB and either have the skirt parallel with the aperature or perhaps incline it forward a bit.
Cutting the LNB will not work, the skirt might not either! but it is a move in the right direction.- Good luck
Steamgauge is offline   Reply With Quote
Old 15-11-2007   #10
jimbo's Avatar
Sounds interesting. I might pop a skirt on tomorrow.
__________________
Jimbo
Old 16-11-2007   #11
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Nah. Won't go with the halter top you normally wear.
__________________
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 16-11-2007   #12
lifes not a practice run
4dbennett's Avatar
My System: technomate diseq 1500ci+ ibm thinkpad
ok 0.6db to 0.4db easy,
measure length of flare
divide length by 3
then lengthen flare by that much
ie
length of flare = 30mm
divided by 3 = 10mm
make flare 10mm longer
= 30% gain
DEEP JOY
dave
4dbennett is offline   Reply With Quote
Old 17-11-2007   #13
koansrc's Avatar
ehm ... I've changed my mind. Sorry guys. It all sounds very tricky and ify. I do believe the techniques would produce functional lnbfs, but can't imagine them increasing my extreme fringe reception of 2D which I had in mind.
It is a bit of suprise that the feed must be lenghtened in order to lower the f/d even though the maths prove it. My logic would have been to shorten in order to "move away" from the dish and widen the angle ( I assume signals enter through the opening of the feed and not "through" the feed sides ). Thanks!
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
