Invacom C120 twin
Thread Tools Display Modes
Old 17-11-2007   #1
koansrc's Avatar
My System: CM 3.0m @ 28.2 w PACE
Invacom C120 twin
Anyone else notice a signal level difference between the 2 outputs ? Output 1 is noticeably ( on a sat meter ) stronger than output 4. Could it be a sign of "wear and tear" for the lnb or is this normal ?
koansrc is offline   Reply With Quote
Old 18-11-2007   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
I presume you mean output 2.
There should be no difference in overall gain levels (mine are more or less equal).
Both output use the same signal path from the probes onwards, the only separation is within the output mux circuit, which is unlikely to vary.
I suggest you check the output terminal socket(s) for possible corrosion.
__________________
Llew is offline   Reply With Quote
Old 18-11-2007   #3
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
I've seen postings (from snap I think) where he has noted that the inner pair of outputs are ever so slightly different from the outer pair (think I've got that right!). Don't remember which make of LNB it was though.
Why it should be so I can't imagine.
__________________
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 18-11-2007   #4
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband!
,when i look,on my signal meter,the freqancy spectrum ,of invacom lnbs,looks real unstable,and the signal tremple!
white invacoms,are the newer ones,o only testet the old gray ones ,and have still in use !
,also,o noticed ,the difrents,of signal on 2.output,on the older inverto lnbs.that takes 200 ma
with newer one white tech,small edition everything is okay!
Turok is offline   Reply With Quote
Old 18-11-2007   #5
koansrc's Avatar
Well I do mean the 2nd output, but it is numbered 4. Looking at the back the metal cast has four positions (1-4) but only 1 and 4 actually have an output.
Old 18-11-2007   #6
koansrc's Avatar
So I guess there realy should not be any difference between the outputs. I thinks I must check the lnb and maybe try a different one too.
Old 28-11-2007   #7
koansrc's Avatar
for what it's worth, I tried an MTI AP8-TW (11€!!) in place of the invacom twin. I used the invacom feed although it doesn't fit perfectly (!) to the lnb. The holes don't EXACTLY line up and the screws can only partially be tightened. The end result is NOT the best fit. HOWEVER, I am now getting better results with the MTI and signal strength has improved to 70% and signal quality unchanged at 95%. No other tuning or tweaking.
I must now look for an MTI feedhorn.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
