Advice needed | |
| Member Join Date: 12-11-2007 Location: uk
My System: just gettin started |
hi everone. ive been loking at the prices to get a hd setup with a passion hd box. the thing is a 90cm satellite with a motor (wthout an lnb) will cost about £100.maplin have got a kit for sale (_http://www.maplin.co.uk/Module.aspx?ModuleNo=221438&doy=18m11&ForceUpdate= Y) that includes a dish, motor, sd lnb and a normal reciever. what i want to know is will it work if i upgrade the lnb to a hd one and buy the passion hd reciever.i could then keep the other reciever and lnb, or sell them on Ebay thanks in advance | ||
| | #2 | |||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! |
Personally I would buy every part seperately and only after making sure about the spec of each part, even if this will cost more. | |||
| | #3 | |||
Personally I would buy every part seperately and only after making sure about the spec of each part, even if this will cost more. Update: Receiver Fortec Star Beta. | |||
| | #5 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | | ||
| | #6 | ||
My System: just gettin started | heres the specs for motor http://fortecstar.com/estore/storefr...&CategoryID=10 fortec says its compatable with all its recievers | ||
| | #7 | |||
Just make sure that the kit includes THIS motor and not some other low end make. There are so many clones. Read some of the threads about motors first. | |||
| The Following User Says Thank You to HB13DISH For This Useful Post: | stephen.rooke (18-11-2007) |
| | #8 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | lol any 40mm universal lnb will work fine, theres no such thing as a hd one you could probably get a triax dish, motor, and technomate 5400 receiver for not much more money | ||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I'm not a lover of the STAB motor, there have been reports of unacceptable play in the arm, I would probably opt for a Moteck SG-2100 and a Fraccaro 85cm Penta dish, a nice combination, add an inverto LNB and you have a good system. ![]() Not sure about the Passion HD receiver, as we haven't had too many reports about them.
__________________ | |||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | | ||
