LIDL Dish Setup .Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 14-12-2007 Location: Ireland
My System: lidl comag sl55 + 80cm sat. | Hello, First time on this forum, Yay Okay, Heres my story; My dad bought this Lidl sat ensamble about 1.5 yrs ago if im right. Its an 80cm dish and a Comeg Sl55 box. We set it up firstly by plugging in the box and then precariously balancing the dish on an old basket ball pole (OK we were desperate to see what we could get on this thiing . Then after about a 1/2 a year later we finally bolted it up to the side of our house (About 12 ft up ) . Then we tinkered with it and received a signal but no ''good'' channels any more :O , Then we got fed up and left it there until now (That was about 3/4 of a yr ago). Maybe those channels at that time were not available anymore (We had our dish in storage for half a year so anything could of happened I suppose),Im fairly sure we picked them up on one of the Astras. Now we cannot get a signal at all from the box, But I know that's because it has moved because of the wind etc. Now we want to move it into the right position, and get some good channels Could you help me ? There is alot of satellites we can pick up according to the box .. but I think the main ones are (Astra 1, 2, Hotbird). Of course we cannot receive all because of the position of our house . When we had our sat in the back garden it was facing SE roughly. Now I think it is roughly facing East .. After all that, Could you please inform me the best position to place my dish (In degrees I think) and I was also wondering if the angle of the dish matters, because I saw some satellite positions on the net (EG AStra 1 East19.2 degrees) but nothing about the vertical angle of your dish . If you could kindly inform me of where exactly to point my dish and IF i can get good channels, That would be great ![]() Barry. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Welcome to the forum Barry. ![]() The dish needs to be within a degree of alignment for each individual satellite, both horizontally and vertically, if your dish is actually facing East, then that is too far, the satellites you will be able to see are 45 degrees either side of Due South.. If you download the Swedish Microwave Calculator and tell it your location, (you can find your location coordinates here) it will give you the elevation and azimuth for each satellite position. You can find the satellite positions and their channel lists at Lyngsat | ||
| The Following User Says Thank You to rolfw For This Useful Post: | B3vcard (16-12-2007) |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi Barry, Welcome to the forum, A south facing wall is the easiest place to mount a dish, as then you woud have a greater choice of satellites to point your dish at. As the satellites are located 22000 miles above the equator at various orbital locations relative to 0 degrees longitude, it is necessary to get both the azimuth and elevation of the dish correct. All the satellites that we can see with our dishes appear as an arc in the sky, with the satellite closest to your longitude at the top of it, with the extreme east and west offsets from this, just about to disappear below the horizon. I find this dish pointer quite easy to use as well. _http://www.satlex.de/en/azel_calc.html To get the best choice of channels available, you may want to consider motorising your dish, which can be done for as little as £40, plus a liitle for a pole and some bracketry. Robbo | ||
My System: lidl comag sl55 + 80cm sat. | Thanks for both your comments. Rolfw, your's were very detailed but very confusing software etc Im sure I could figure it out eventually. I found the SatLex _http://www.satlex.de/en/azel_calc.html site very good .. Was very simple to understand, and I could use the Lyngsat (http://www.lyngsat.com/) site to see what channels were on what sat's.So , Could I just use the SatLex site + the Lyngsat site for doing all my calculations ? Or am I cutting corners somehow :P Barry. | ||
| Last edited by Robbo; 16-12-2007 at 06:07 PM. Reason: Remove live link to another forum | |||
| | #5 | ||
| Member Join Date: 03-05-2004
| just a side note .. i think there is new patches for that box aswell that will clear a few good channels ![]() so if you install your dish to 19.2 or 13 maybe 1w you may be able to get the best out of your box | ||
| | #6 | ||
My System: lidl comag sl55 + 80cm sat. | I assume you are talking about the ''unofficial'' firmwares out for the box. Could someone actually tell me what extra features those firmware/s give me ? Couldn't really understand it. Barry. PS: What ''good'' channels ? | ||
| | #7 | |||
Robbo | |||
| | #9 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | It means you can decode some of the foreign packages like Premiere(19E), Polsat(13E), TPS(13E),DigiTV(1W) for example. I have not a clue what you use or how to do it with the Comags, but I have a sneaking suspicion that andysly has. It might not even be possible with your rec. | ||
| dish, lidl, setup |
