No Signal - Wind moved LNB?
Old 09-01-2008   #1
My System: Sky+
Unhappy No Signal - Wind moved LNB?
As i'm sure you are all aware, there were bad storms yesterday across the UK. Is it possible my dish or LNB were moved during the high winds? Been getting a "no signal" since yesterday and wonder if this is something i could fix easily. Is it likely to be this? I've checked all cabling, performed an LNB reset etc.
Not sure if this happens often in high winds / extreme weather and i'd like to avoid paying an engineer if its somethign i could fix easily.
With Arsenal v Tottenham on tonight and a brand new sofa waiting for me, i'll be gutted if this isnt easliy fixable!!
Cheers, any advice would be appreciated.
BoysieUK is offline   Reply With Quote
Old 09-01-2008   #2
rolfw's Avatar
Real name: Rolf
There's a fair chance that the dish has moved, if it has, then minidishes are quite easy to realign. It is unlikely that it will have moved too much, so nudging it back a small amount at a time will normally produce results.
Rolf
Old 09-01-2008   #3
My System: Sky+
Great - i'll give it a go asap. Thanks for the advice.
Old 09-01-2008   #4
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
If there are other dishes you can see while looking at your dish, it will give you a clue where the direction should be.
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 09-01-2008   #5
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
Don't forget to give the bolts a quick tighten up once you're done, hopefully it'll stop it being blown about in the future...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 09-01-2008   #6
My System: Sky+
Thanks for all you help.
Could well be back later on if reallign doesnt work!!!
Old 09-01-2008   #7
My System: Sky+
Unhappy
unfortunately this didnt work. The dish is rock solid and nothing has moved. There was apparently a brief powercut last night as well. Could this have done it?
lnb, moved, signal, wind
[IMG] code is Off
