gibertini dish elevation bracket | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master dish @1west, vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish |
does anyone have a close up picture of the dish elevation bracket as i want to see how it looks why because today i went to tweak my triax dish and altering the elevation bracket and it doesn't allow small adjustments as it doesn't run smooth up and down rolfw, have you got a picture of the penta 85 cm dish as i would like to see the back of that too if you have | ||
| Member Join Date: 07-02-2007 Location: Budapest, HUNGARY
My System: Gibertini 125cm, SMART Titanium 0,2 LNB, motorized, Manhattan Plaza, SS1 card | Hi Wod, Here are two pictures of my Gibertini 125. It is attached to a Jaeger Superjack 1224. Hope this help ! Balazs Gib1.jpg Gib2.jpg | ||
| | #3 | |||
| Guest
Posts: n/a
| You want to get one of the new raven dishes with the micro adjust you and see the dish in this video http://www.ses-astra.com/medialib/co...Connect_EN.wmv just pretend it has got a normal LNB-F on it and not a i-LNB (receive & transmit lnb-f), See in the video how you can fine tune the dish with the allen hex key
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | The fine adjustment is good on the Penta dish Wod (not sure whether I have a photo), on the Gilbertini 1.25, it has a threaded rod for fine adjustment. I've never liked the adjustment on the TD range and no longer use them, for that and other reasons.
__________________ | |||
| | #6 | |||
any idea if there available to buy separately and in which sizes ? in two minds at the minute as after these winds we've had my dish is wrecked basically well the motor is doesn't like to go west now benko5009, thanks for those pictures the gibby on 1224 is also an option as i have a 1224 boxed up here at the moment. | |||
| | #7 | ||
My System: Gibertini 125cm, SMART Titanium 0,2 LNB, motorized, Manhattan Plaza, SS1 card | Hi Wod, If you decide to use Gibby with 1224, you'll need also the adapter plates to join the dish to the rotor arms. (perhaps you can see the adapter on one of my pictures) Succesful installation ! Regards, Balazs | ||
