newbie LNB query (my frequencies differ from lyngsat)
Thread Tools Display Modes
Old 19-02-2008   #1
My System: Fortec Star Beta Sky+
I have a dish on the side of my house aligned to 19.2 from the days of analogue sky. For a bit of fun, I bought a cheap FTA digital STB (Fortec Star Beta) despite having no idea what type of LNB is on the dish.
I quite easily found 180 or so FTA channels but I've noticed that the frequencies displayed on screen are different to those listed on lyngsat.com.
For example....
ARTE (tp24) should be 11568, but displays as 11318 on my box.
KTO (tp22) should be 11538 but displays as 11285 on my box.
(note: the discrepancy is about 250)
I'm guessing this is something to do with the LNB? Does it mean I don't have a universal LNB? If this is the case, what LNB frequency should I be using on my Fortec?
Sorry if this is a dumb question! I'm pretty new to Satellite stuff! Thanks.
sat-newbie is offline   Reply With Quote
Old 19-02-2008   #2
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Hi, you are best off simply replacing the LNB for a universal LNB, they are extremely cheap, as it sound like you don't have one. Try one of the site sponsors.
The local oscillator in yours may be at a different frequency, also you may not be able to cover both the low and high bands. By my calculations the LO in the LNB = 10,000MHz.
(11568-X)+9750=11318, where x =your LO freq)
You may be able to correct the frequencies by altering the LNB type in the menu or by changing what LO it thinks the LNB has.
Robbo
Robbo is online now   Reply With Quote
The Following User Says Thank You to Robbo For This Useful Post:
sat-newbie (20-02-2008)
Old 19-02-2008   #3
rolfw's Avatar
Sounds like an old 10Ghz LNB by the frequency shifting, very old, you can still probably set the receiver to 10Ghz local oscilator, but it will severely limit what you can receive. As Robbo says, replace it with a universal. Click on my signature for list of advertising supporters.
PS sorry Robbo, didn't read your post properly and now realise I've just pretty much repeated what you said.
__________________
Rolf
Donate
The Following User Says Thank You to rolfw For This Useful Post:
Old 19-02-2008   #4
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
Yes - its 250 MHz out so the lnb is an old 10MHz single band type. You need to put the aformentioned universal lnb onto it.
Give the bolts that hold the lnb plastic collar in place a good dousing in oil & WD40 at least a couple of hours before you start - chances are they will be rusty!
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
The Following User Says Thank You to Analoguesat For This Useful Post:
Old 19-02-2008   #5
Robbo's Avatar
Originally Posted by Analoguesat View Post
old 10MHz
Would that be 10 GHz AS?
Old 19-02-2008   #6
Site administrator
Oops!
__________________
Analogue forever!
Old 20-02-2008   #7
Thanks everyone. It's nice to see such a knowledgable and helpful group here.
Robbo 71 wrote....
>the LNB has.
Any suggestion what settings I should use? On the setup page, the available LNB frequencies are 5150, 10750, 11250, Universal, or enter a number manually. Of the presets, only 'Universal' seems to work.
One final question, how easy is it to change to a universal LNB and what tools will I need.
Thanks again.
Old 20-02-2008   #8
Site administrator
Dead easy IF you have completely safe access to the dish. The are are probably a couple of bolts or nuts and screws holding the plastic collar that grips the throat of the existing lnb..
Douse them in oil & wd40, undo them, slide the collar off and reverse for the new lnb. A 10 minute job if the bolts arent seized solid.
Please - DONT try it if the dish is 40 feet in the air, or positioned above a glass conservatory! (Both of which Ive seen....) Or if you are at all unsure about your DIY skills - call in an expert in these cases.....
__________________
Analogue forever!
Old 20-02-2008   #9
Robbo's Avatar
Robbo 71 wrote....
>the LNB has.
Thanks again.
You would have to enter the number manually. That is 10000. Then do a rescan.
When/If you get a new LNB, you would change it back to Universal, the already scanned in channels would still be correct.
Old 20-02-2008   #10
Thanks again for the advice. Setting the LNB to 10000 and re-scanning did the trick.
However, I do intend to buy a universal LNB.
I've been looking on Ebay and there seem to be loads of bargain LNBs but many don't explicitly specify 'universal', eg....
http://cgi.ebay.co.uk/NEW-WNC-SINGLE...QQcmdZViewItem
http://cgi.ebay.co.uk/NEW-THOMSON-DI...QQcmdZViewItem
Is it safe to assume most LNB's are universal these days?
Also, some LNB's quote a noise figure. One I was looking at specified 0.6dB. What is a good/bad noise figure?
And my final question, there are lots LNB's on Ebay "suitable for sky digital". Are these suitable for my needs? Thanks.
Old 20-02-2008   #11
Robbo's Avatar
Is the dish elliptical i.e wider than it is taller?
Or is it more of a round shape?
The sky digital LNBs are specifically for Sky minidishes, which are elliptical.
You want a standard 40mm neck LNB I believe (check the mount).
Yes most are universal. I find my Inverto Silvertech 0.2dB works pretty well, slightly better than the other two I have.
The lower the noise figure the better, but the figure can't really be relied on anyway.
The Sky minidish LNBs I think are generally 0.6dB.
Old 20-02-2008   #12
Site administrator
Good stuff - although be advised you will be missing all the channels in the top half of the band. The cutoff will be somewhere between 11700 & 12000MHz
__________________
Analogue forever!
[IMG] code is Off
Forum Jump
