Dish extension panelsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 01-09-2007 Location: Derbyshire UK
My System: Echostar ad3600ipva Technomate Tm5500cip Sky+ Technisat DVB pci 2.3 & 2.6 running on XP & Vista with Prog DVB 1.5 prime focus dish on polar mount Invacom C120 quad LNB T Rex cam, Diablo cam & Matrix reloaded cam Cas 3 plus programer |
I have what I believe to be An IRTE 1.5 prime focus dish that I have been using for many years. I seem to remember reading somewhere that extension pannels where available for this dish to increse it to a 1.8 or 2.4 The question is am I remembering corectly or is it just wishfull thinking. If these do exist does anyone know where I might find them? | ||
Well it begs the question why? What can you not currently receive that you think you should be able to? you see I come from the "if it ain't broke dont fix it" camp | ||
| Member Join Date: 22-05-2003
| I have an IRTE 1.5m dish and an IRTE 2.0m dish. The later is like the 1.5m but has a set of 6 extension petals which bring it up to 2.0m. The stand alone 1.5m dish does not have the same outer edge to it as the inner 1.5m dish integral to the 2.0m ( which has pre-drill holes to add on the petals). Have a look at the IRTE web site under consumer satellite dishes and you will see the two dishes mentioned ( along with others). It may be possible to add a set of these petals if IRTE are willing to make them available. But beware these are expensive dishes. I dealt directly with IRTE UK. I would contact them. They are very helpful. Good luck. As regards what it can get you. It gets me 7W Hor channels, but I am in SW Eng. Unlikely to make a difference in the Midlands, going from 1.5m to 2.0m with respect to 7W hor channels.. | ||
My System: Echostar ad3600ipva Technomate Tm5500cip Sky+ Technisat DVB pci 2.3 & 2.6 running on XP & Vista with Prog DVB 1.5 prime focus dish on polar mount Invacom C120 quad LNB T Rex cam, Diablo cam & Matrix reloaded cam Cas 3 plus programer | Im looking to fit a combined C/Ku LNB setup & was thinking that the increse in dish size would componsate for the loss caused by the feed casting a bigger shadow on the dish. Besides doesnt bigger usualy mean better in regard to dish size | ||
| | #5 | ||
So what C-band transmisssions will you go for as I think there is not much to be had in our arc! and your location appears to be Derbyshire As for the shadow, the difference will be minimal but yes for C band the bigger the better, you may however find you are swamping your stb with signal when viewing ku band transmissions. It depends on the type of stb | ||
| | #6 | ||
| I have just bought a BSC 621-2 C-band & Ku band combined LNB to try in my 2.0m dish. Have contacted IRTE UK about how to attach this as the supplied scalar ring with the said LNB presents a tricky attachment. Will let you know how I get on. By the way, this LNB only requires one coaxial cable as there is a diseqC switch to turn between the C & Ku bands. | ||
| | #7 | |||
The rim is quite flat and is 31mm deep | |||
| | #8 | |||
I used to recieve C band in the analouge days but I never had a combined C/Ku feed and swapping the feeds was a pain. Recievers I use are Echostar 3600, Vantage & Clarke Tech HD5000C | |||
| | #10 | |||
| | #11 | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #12 | ||
| | #13 | |||
| Regular Member Join Date: 20-04-2006 Location: Lost in the night
My System: ? | You need to calculate the new focal length. | |||
| | #14 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Perhaps being a bit dense here, but if an existing dish focuses at a certain point, surely the addition of panels to it, will not change the focus of the original part of the dish. I would have thought that extension panels would be designed to focus on the original point. | ||
| | #15 | |||
My System: ? | 1m dish: small poles 2m dish: longer poles 7m dish: much longer poles. The focal point gets far away as diameter increases. | |||
| | #16 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I agree with you when relating that logic to standard dishes, but you are not comparing like with like. If the original 1.5m dish has a certain focal length and focal point, how can adding extra panels on to it, change the focal point of the original part of the dish? | ||
| | #17 | ||
I have to agree with your logic there Rolf, the original geometry of the dish remains the same and the extra petals are also focussed to the existing focal point. I think that tesla is perhaps getting confused with illumination areas and waveguides. When a dish is engineered to the specific sizes that he mentions yes the focal point does increase as the diameter of the dish increases because the curvature of the dish decreases the bigger the dish diameter becomes | ||
| | #19 | |||
If somebody designs a dish to be either one size with an option to have petals with a greater diameter, they are going to use the less curved option thus longer focal length whether the extensions are used or not IMHO | |||
| | #20 | ||
My System: Echostar ad3600ipva Technomate Tm5500cip Sky+ Technisat DVB pci 2.3 & 2.6 running on XP & Vista with Prog DVB 1.5 prime focus dish on polar mount Invacom C120 quad LNB T Rex cam, Diablo cam & Matrix reloaded cam Cas 3 plus programer | Just been reading this on www.primefocus.com/cband_instal.html A Word About Focal Depth The f/D ratio is the focal distance of the dish (f), divided by the diameter (D). When dealing with most prime focus antennas, the number should come out between .28 and .42. If you notice, most of those numbers are also on scale on the side of the feedhorn. You simply set the top edge of the scalar ring even with the line that corresponds to your correct f/D setting. What this adjustment actually does is determines how wide of an angle the feedhorn can "see". To calculate the focal distance, you have to measure the diameter (D) and the depth (d) of the dish. Measurements should be in like units (you can'tuse feet for the diameter and inches for depth). For the example, let's say we have a dish that is 120 inches in diameter (D) and 18 inches deep (d). Focal distance (f) equals the diameter squared (D x D) divided by 16 times the depth (16 x d) or : D x D = 120 x 120 = 14400 16 x d = 16 x 18 = 288 D x D/16 x d = 14400/288 = 50 Therefore focal distance f = 50 inches After you have calculated the focal distance (f), you can use that figure to calculate the f/D ratio of your dish. In this case, using the same diameter of (D) = 120; and the calculated focal distance (f) = 50 f / D = 50 / 120 = .416 f /D = .416 You would round up to give a setting of .42. I had wondered about this but as I will probably never find these pannels at a reasonable price I wont get to experiment. Ive made some alterations to the polar mount today & fitted a 36" motor arm. I can now recieve 58w to 42e. The dish can see further east but I havent found anything yet. Have also ordered a C/Ku lnb from Germany so the improved arc should give me plenty to try for. | ||
| | #21 | ||
| Yes the 1.5m has an F/D of 0.41 and therefore has a focal length of 61.5cm. The 2.0m dish has an F/D of 0.40 and a focal length of 80cm. The feed tripod poles are at an angle out from the dish and are therefore longer than these values in each case. | ||
| dish, extension, panels |
