Is the invacom quad better than single
Thread Tools Display Modes
Old 26-02-2008   #1
Rd100
Posts: n/a
Is the invacom quad c120 better than the invacom single out put c120 has any one tested both,
Old 26-02-2008   #2
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
I have found the Twin and Quad to be significantly better than a single for Astra 2D on the 3.1M dishes we use here.
BUT....
The single performs better when using the same dish for Eurobird S1.
Here in Lanzarote we cannot get 2D and S1 on the 3.1M dish succesfully at the same time. We have to peak to one bird or the other. If we try and align best between the two then both usually suffer with signal problems.
Hope this helps
Triggs
trigger is offline   Reply With Quote
Old 26-02-2008   #3
My System: dell
I have both invacom single and quad,tested with 1.80 dish in west bulgaria,with invacom quad better works on astra2D/i found only vertical transponders/and horizontal transponders on high band but single invacom works better only on vertical transponders tested on 12.441V astra 19E but quad works better on vertical transponer on Sirius4 INVACOM QUAD is the winner
piratt is offline   Reply With Quote
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
