Is it possible? | |
| Member Join Date: 19-02-2008 Location: Nottingham
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs |
Is it possible to tune in to these 3 sats, 9E, 19.2E and 28.2 E using a fixed dish with 3 lnb multi bracket or is the span too great? If so which one should I set (focus) on first. Thanks | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | A 90cm Raven Gemini with East and West Offset brackets would probably do it, use 19.2 East as the central satellite, might as well throw in an LNB for 13 East as well. You could of course try it with your 70cm and see how well it works.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | RobHoo (27-02-2008) |
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | Thats great Rolfw, thanks for the quick reply.. i'll give a go and let you know how I get on, cheers.... | ||
Hey Rolfw... the eurobird 9 is not in my list of Sats on my reciever? does that mean there's no way I can pick it up? | ||
| | #5 | |||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | If you can't work out how to do it, you could use a position that you are not going to use as a last resort, and just change the transponder frequencies.
| | #6 | |||
| | #7 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | If you are focussed on 19E, 10E should be on the right when facing the dish. It also needs to be slightly lower, as 10E is higher in the sky than 19E. If the bracket has degree markings on it, put it at about 9 degrees to the right. Then duck down below the dish a bit and adjust for best signal quality. Also remember you will need to adjust the skew a little too(clockwise a bit, looking a the dish face) Robbo ![]()
__________________ Last edited by Robbo71; 01-03-2008 at 01:11 PM. | ||
| | #8 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | Not a sniff!... maybe the dish isnt big enough. Ive even tried making it the main focus using the center lnb and moving the dish to try and pick it up but still cant get it... | ||
| | #9 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Which transponder are you looking at? I'm just doing a blind scan on 9E at the moment to see what I get.I'll let you know if I find a strong one. ![]()
| | #10 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Ok, try 11843V 27500 3/4. (9E) I'm getting a gopping great signal on that transponder. showing B4 music India. (free to air) Robbo ![]()
| | #11 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | How do I do that? lol.. Im new to all this... Im looking for this channel, MelodyZen TV HD | ||
| | #12 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | That is on 11958V 27500 3/4. Just checked, that is another very strong transponder, you should be able to get it on focus at least with your 70cm. I can't give the precise details how to get it on your receiver, but in general: In the setup menu somewhere, go to the settings for 9E ( or 10E if you are using that), then add new transponders (if not there already) for the two frequencies I just mentioned, also set their symbol rate (27500) and their FEC (if not automatic) and of course H or V. Then with the dish at that position, with one of those transponders selected, get a signal strength/quality meter up on the receiver, monitor signal and adjust the dish. Robbo ![]()
| | #13 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | Thanks Robbo, but remember I havn't been able to find a signal for 10E at all. Like I said Ive tried moving the dish etc but without a flicker.. surely I have to find the satellite before trying what you say? | ||
| | #14 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | No, you need to enter the transponder details in first, if they're not already there. You need to do this so that you can find the satellite. The transponders in your receiver already may be too weak/impossible for you to pick up. Wheras if you put in one that is really strong, you have a chance of picking it up, and can use it to adjust the dish on.
| | #16 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | unable to alter them... there are some values in LO whatever that is but 11450 is the highest I can choose | ||
| | #17 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Leave the LO (Local Oscillator) alone, it should be set at universal, 9750 and 10600. You should be able to add transponders on all receivers, just a matter of finding where. ![]()
| | #18 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | On this reciever it only gives you that option after reception and before scanning for channels.. thanks anyway Robbo.. may have another try tomorrow.. cheers | ||
| | #19 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Your receiver does allow you to enter transponder frequencies manually, just like any other receiver. Have a look at the quick start guide, Network Scan:-
| | #20 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | Yes but the "Network Scan" screen only appears after the "Reception" screen, where the signal strength if any is shown.... or am I missing something here.... | ||
| | #21 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | When you go into the satellite set up screen, it normally lists a default transponder, this can in most cases, be clicked on to change to the one you need to look for.
| | #22 | ||
My System: Pace DS810XE Raven Gemini 70 dish Multi Bracket, 3 Inverto Silvertech 0.2 LNBs | what I think I need to do is to change one of the existing sats that I will never use to the frequencies Robbo suggested if I can and try that.. | ||
| | #24 | |||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | The transponders are the the things in the satellites that sends us the signals, each one is on a different frequency for each satellite. So in essence, for Transponder read Frequency. It is a pity Pace charge £1.50 to download a PDF copy of their manuals. ![]() as I suspect the full information is not contained within the Quick start guide.
| | #25 | |||
