monoblock question ??
Thread Tools Display Modes
Old 02-03-2008   #1
My System: technomate reciever 5500 ci super, astra 19.2 E and 28.2 E
hi all im a newbie in the sat game but getting lots of help from all on this site.
i hve currently got 2 fixed dishes and looking into getting a monoblock for my 19.2 dish .. in order to recieve hotbird 13 e can anyone recomen a good lnb ive looked on fleebay but really not sure what im looking at .. and is it ok two have the 2 satellites into the same box or do i need another box???
thanxs
mcdet8 is offline   Reply With Quote
Old 02-03-2008   #2
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Hi, for 19.2E and 13E you just need a 6 degree monoblock LNB. Is your dish large enough? as some of the Hotbird beams appear to be a weaker than the Astra (19.2E) beams for your area:-
_http://www.lyngsat-maps.com/maps/hb6.html
_http://www.lyngsat-maps.com/maps/hb7a.html
The monoblock LNB has an integrated DiSEqC switch, so only one cable is fed to the receiver, so only one receiver is required.
Robbo
Robbo71 is offline   Reply With Quote
Old 02-03-2008   #3
thanks for your reply .. looking at the map it appears my dish would be too small but i have a larger dish 1.3m pointed at 28.2 .. but obviously further from 13 e .. would that be too much of a gap ..
thanks
Old 02-03-2008   #4
Robbo71's Avatar
The further away from the focus the worse the signal is, I don't think it would work on that either, but there is no harm in trying, you may pick up the stronger transponders on either dish, give it a go.
Motorising your 1.3m dish would be your best option, or get another 1.3m dish.
Old 02-03-2008   #5
thanks i think ill give the monoblock option a try .. is there any manafacturer that you could recomend as it might be a lot to ask with the 2 dishes in there current possison thanks for you help...
Old 02-03-2008   #6
Robbo71's Avatar
I'm not a dish expert, but I gather than the fibreglass dishes made by ASC signal (formally Andrews and Channel Master) are the sort of dish that the professional use.
Old 05-03-2008   #7
My System: ?
I think (although I'm not 100% sure) that the monoblock LNBs are suitable for 80cm dishes only.
tesla is offline   Reply With Quote
Old 05-03-2008   #8
Robbo71's Avatar
Yes good point. I believe they are optimized for 80cm dishes, but can be used for other sizes near that as well.
As long as the angular offset from the focus is about 6 degrees it will be fine. The offset LNB isn't properly focussed anyway, hence the drop in signal.
Old 05-03-2008   #9
aba
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
instead of useing monoblock lnb use two seperate lnbs with a disque switch then it dont matter what size dish you use
aba is offline   Reply With Quote
Old 05-03-2008   #10
My System: 28.east fta, 19e and 13e tm1500ci
Yes I have also got 13 and 19 on a monoblock. got it from wizzard bargain only £12.50
chucklebezza is offline   Reply With Quote
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
