dish moved
Thread Tools Display Modes
Old 02-03-2008   #1
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12
dish moved
hi guys i have lost thor 1d west with the bad wind whats the best way to get it back all my other satelites are ok will i have to move my dish if so iam a fraid that i will lose the others
den123 is offline   Reply With Quote
Old 02-03-2008   #2
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Hi, have a read through rolfw's motor setup guide:-
http://www.satellites.co.uk/satellit...or-others.html
Your motor has probably moved round the pole a bit.
If you follow the guide you will be able to get the dish re-aligned without losing any other satellites.
Robbo
Robbo71 is offline   Reply With Quote
Old 02-03-2008   #3
thanks mate will give it a go
Old 02-03-2008   #4
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
also check the dish is centered on the motor pole first as just that could have moved abit either way
Old 02-03-2008   #5
mee
My System: IMAX
Hi i am Mee can anyone help me i have lost nilesat and turk sat due to the strong wind how can i get them beack
mee is offline   Reply With Quote
Old 02-03-2008   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Depends how much it's moved. If the mounting's twisted laterally , you may be able to reposition it while someone checks the picture.
P.S - you don't need to post the same question twice, wait for a reply.
__________________
Llew is offline   Reply With Quote
Old 02-03-2008   #7
hi guys mine dish add move on the motor arm connection judt move dish uo a bit all ok now
Old 02-03-2008   #8
wod
make sure the bolts on the dish bracket are really tight and add another nut to each of the bolts
The Following User Says Thank You to wod For This Useful Post:
den123 (02-03-2008)
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
