Old Triax 140 Prime Focus
Thread Tools Display Modes
Old 02-03-2008   #1
My System: DB7000S+HDD+USB2GB; FTE MAX S102; CM120, Triax110,Norsat7706A on 7°W; Triax 110 and 88; Bigsat 85. LNBFs: 2SatconnQ, 2InvacomQ; 5Alps, 3inverto, 1BigsatMb; Sundry switches and M/S; Centauri P-168. 30w, 8w, 5w,1w,5e,9e,16e,23e,28e;13E,19E;26E;7W
I just acquired an Old Triax 140 Prime Focus dish.
I do not know anything about it.
I am asking you guys what you think of it before I take it up 13 floors to install. I know Turok has one of those.
How does it compare with my CM120 offset dish?
Thank you
canofan is offline   Reply With Quote
Old 04-03-2008   #2
I have found an image of a similar dish which I join to this post.
Old 13-03-2008   #3
This dish was installed on the roof of the Hilton Hotel in Brussels and belonged to the suite of the Emir of Abudhabi. It was used to bring in Nilesat, and, according to the installer, it was bringing in all Nilesat, rain or shine. The reason that it was removed was that it was not in possession of an "urbanism permission"
It is made of aluminium and the dish itself without the mount does not exceed 3 Kilos.
I paid 50 Euros for the whole lot including a heavy 10 bolt wall base with a 70mm mast.
Old 29-04-2008   #4
_http://www.rewindmuseum.com/vintagesatellite.htm
this web page has a description of a system from the late 80s which include this dish
Old 29-04-2008   #5
My System: 3x Dreamboxes 13°, 19.2°, 23.5° & 28.5° East 7°, 8° West 2.4m Aerial Oy for Nilesat Subs: Canal+/Sat France, Premiere/arena, TV Vlaanderen
I live near Brussels and I have a 2.4m PFA for Nilesat.
Frankly, it is not serious to pretend to get all Nilesat, rain or shine, with a PFA 1.4m. The horizontal transponders will not work (Showtime).
charly20 is offline   Reply With Quote
Old 29-04-2008   #6
I never thought it did but the installer on the Hilton said so.
The matter is still to be verified.
I removed the dish for the time being while I gather the necessary elements to make it work at its best.
I am far from having all.
Old 29-04-2008   #7
ok; keep posted on progress...
Old 29-04-2008   #8
Even though some forum members may find this post boring. I decided to post this anyway.
Having given the task of verticals on Nilesat to a Triax110 with an Invacom, I already receive horizontal transponders on Nilesat with a good percentage reserve on my Channelmaster CM120 plus CM911-6060-10 feedhorn and a Norsat 0.6db. My assessment of the situation is not yet final as I have not had very nasty weather since the beginning of this experiment.
My feedhorn, however, has a circular throat and I had to use a transition to WR75. This certainly increases input noise. I am waiting for a feedhorn with a rectangular throat (WR75 output) this would dispense me from using the transition. I expect, this way, an improvement of the input noise characteristic.
The bigger area of the Triax140 gives the potential of increasing reception by 1.34db over my Channelmaster. Hence my search for a WR75 PF feedhorn designed for the standard band in order to improve on the same favourable combination required for the Channelmaster.
All this because I do not want a 180cm dish on the 13th floor of the building.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
