dish moved | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | mines not moved at all but we didn't have much or any wind at all overnight it will move again with that dish i was surprised you didn't buy the polar mount and 12 inch actuator for it and use that much better than a diseqc motor | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I second that - my polar mount / actuator's been rock solid despite the best efforts that the current weather conditions (should be - it's clamped to a dirty great 3" steel pole )Llew | ||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: technomate diseq 1500ci+ ibm thinkpad | | ||
| | #5 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | It's an adjustable mount that enables the satellite dish to follow the satellite arc. An actuator is mounted between the dish and a hinged point on the mount. The motor in the actuator controlled by a positioner moves the dish to the required satellite on the arc. You would normally buy a matched dish and polar mount (e.g. Andrews, Gibertini ) You could check out our sponsors, they may have something suitable. A typical mount and actuator is shown here - | ||
| | #6 | ||
| Regular Member Join Date: 21-06-2007 Location: Watford , Herts , UK
My System: Channel Master 1.2 driven by Supermount SMR 1224 mount. V-Box 11 Triple Dragon Linux Receiver. Vantage VT-X221TSCI Blindscan Receiver. Diablo Wireless cam and base. 42" Panasonic Plasma Lots of boys toys! | Its a question of quality. My 1.2 mtr Channelmaster and heavy duty mount hasnt moved a millimetre. Gibertini dishes are good as a budget dish but disecq isnt the most stable of mount in a strong wind environment unfortunately! | ||
