Kathrein CAS dishes | |
| Member Join Date: 04-01-2006 Location: Northern Ireland
My System: 45w-45e 80cm DM500-S |
Hello, I'm thinking of maybe upgrading my dish to something a bit larger and newer so I was thinking of maybe one of the Kathrein CAS dishes, I was thinking of the CAS90 . Does anyone here have any experience with them, and are they a good buy or should they be kept away from? Cheers | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master dish @1west, vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | yes they are a good buy but are quite expensive and very good build quality what about a 1metre gibertini dish these are not expensive and good quality ? | ||
My System: 45w-45e 80cm DM500-S | Would the gibertini give just as good preformence as the kathrein?. Ideally, Id like a dish which would give as good performence as possible and about 1metre in size because anything larger would not go down well with headquarters! | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You could perhaps look at a Gregorian dish (Fibo type), they certainly punch above their weight, but are quite expensive.
__________________ | |||
| | #5 | ||
My System: 45w-45e 80cm DM500-S | What sort of money on average would we be talking about for a Gregorian dish?. I was doing a bit of a search and I see a place sells gregorian dishes(??) under the name of masterfocus. | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Have a look in the fibo section above, I think there are some prices mentioned in there.
