Can anyone help, please?
Thread Tools Display Modes
Old 15-03-2008   #1
My System: DB7000-S
My old Grundig gregorian dish with a built-in 36v motor sadly died last week. I have now bought a Triax 1.1m dish and a Jaeger SMR-99G H-H 36v positioner and desparately need some help. The install location is near to Bognor Regis, West Sussex, Lat 50.77N Long -0.740 . Please, can anyone help me by supplying the settings for the Triax mount and the settings for the Jaeger mount?
Regards
SatGnome
SatGnome is offline   Reply With Quote
Old 15-03-2008   #2
rolfw's Avatar
Which Grundig dish is this, the 90cm or 1.2, if you look in the Fibo members' section, there are new and reconditioned units available. Don't discard the dish, it is better than most of the opposition.
__________________
Rolf
Donate
Old 15-03-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Regards
SatGnome
Yes, it is a shame to not use the gregorian still.
For the HH motor you will need to set its elevation to match your latitude.
The dish elevation (called the declination) can be set by adjusting for max signal on Thor 0.8W (11325H-BBC World), after driving the motor there.For you, it is easy as it will be near as dammit at zero.
My Triax 110 is just tilting back a few degrees when I'm on that sat.
Robbo71 is offline   Reply With Quote
Old 15-03-2008   #4
My System: DB7000-S
Thanks to Rolfw and Robbo71 for your help. Rolfw, the grundig dish was a 90cm and as I havn't thrown it out yet I will check out your suggestion, many thanks.
Regards SatGnome
Old 16-03-2008   #5
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
keep the dish, dont bin it
you should have bought the jaeger 1224 motor and modified the adapter plate and used your gregorian dish as it will be better than the triax 1.1m
anyway with the smr 99 motor you need to use an angle finder or inclinometer and set the motor elevation with the long screw on the back of the motor
then once the dish is on you just find thor 1west with a meter and adjust the dish elevation for best signal
the elevation bracket on triax dishes aren't 100% correct
The Following User Says Thank You to wod For This Useful Post:
SatGnome (16-03-2008)
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
