Another Dish Size Question | |
| Member Join Date: 04-03-2008 Location: guernsey
My System: none |
Hi I've been trawaling through the normal sites for dish size's etc and as i live in the channel islands the recommedation is 50/55cms ????? does any live on the southcoast of england or normandy that can give me an idea of minimum size dish i can get away with a discq motor ? Thanks ![]() Last edited by joselin; 17-03-2008 at 05:32 PM. | ||
| | #2 | |||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
You can motorise a really small dish if you want, but your choice will be limited to say 13E,19E,23.5E,28E,42E + a few others. Most people go for an 80cm to 1m dish for a Diseqc motor. Robbo ![]()
__________________ | |||
| The Following User Says Thank You to Robbo71 For This Useful Post: | joselin (17-03-2008) |
| | #3 | |||
My System: none | Another question slightly different though. Is there likely to be signal decay because of distance from dish to receiver with the technology these days? | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, that is a measurable factor, determined by the type of cable you use over the distance. How long is the cable run? Also have a look at the Fracarro Penta 85cm dish, our supporting advertiser High Definition Ltd sells them. ![]()
| | #5 | ||
My System: none | its going to be 30m ish, can you recommend a cable type i should be looking at ? | ||
| | #6 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | 30m ish would be OK. An approved 100 type cable like wf100 would do the job. This cable has a foam filled dielectric, there are also semi-air spaced dielectric cables such as WC100, which is less crush resistant but performs the same. Robbo ![]()
| | #7 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | | ||
