hi help needed with 1224 supermount setup
Thread Tools Display Modes
Old 19-03-2008   #1
My System: triax 90cm dish echolink 888 recever diseg motor
hi need help doing settings on jaeger 1224 super mount how to set declanation elavation ect i have a inclineometer to help me but dont no wot to do
sys setup
1.2 andrews channel master
jaeger 1224 supermount
ivacom lnb and feedhorn
technomate 1500ci+
vbox 11
also i need help setting the polar mount up for use at the moment
also 1.2 andrews channel master
superjack
polarmount
echostar 3600 ip ad
r1chard06 is offline   Reply With Quote
Old 19-03-2008   #2
My System: Channel Master 1.2m, Vantage VT-X221TS CI, Technomate V-Box II, 18" Superjack actuator
Rolfw kindly scanned and uploaded his polar mount manual when I was having difficulties a few months ago. You will find it here. If you need anymore help then post back here. I haven't got a 1224 motor yet so cannot help with that.
michael01707 is offline   Reply With Quote
Old 19-03-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
The 1224 is an Horizon to Horizon mount isn't it?
I have not got one either, but looking at the picture, the screw thing at the bottom is used for adjusting the elevation. The elevation should be set to 90-latitude.
As for the declination, it looks like the screw at the top does that, normally with an H-H motor this can be set by adjusting for best signal on the satellite closest to you due south.
Robbo
Robbo71 is offline   Reply With Quote
Old 19-03-2008   #4
re polar mount
thanks for help so far wot should i set my polar mount to my post code is s65 3rj lockwood close
Old 19-03-2008   #5
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
no you set the polar mount elevation to the latitude of your location as for example mine is set to 37degrees which is 90-latitude figure
so on the 1224 motor you adjust the long threaded bolt to your latitude setting with an inclinometer and then adjust the dish elevation by loosing the top two offset brackets on the adapter plate to tilt the dish forward or back when aligning to your reference satellite
some pic below of 1224 motor
Old 19-03-2008   #6
re jaeger 1224
i may sound thick here but here goes so wot you are saying is move long bolt til i get 37 on inclineometer as think that is same as mine and then on the top plate adjust that to 90 using the inclineomiter hope thats wot you mean
Old 19-03-2008   #7
wod
you need to get your local coordinates from multi map etc
then as in the picture adjust the long bolt with the inclinometer on the motor to your setting and tighten the bolt up.
then on the dish side align the dish on thor 1west as i see your in the uk and you need to use a meter and adjust this for best signal on say 11325h bbc world
as we cant say what to set the dish to as you might not track the arc properly
Old 19-03-2008   #8
hi
my numbers are
Lat: 53:25:58N (53.43281)
Lon: 1:19:10W (-1.31946)
so wot would be my setting also do you no were i could get a good ground stand for 1.2 cm dish
Old 19-03-2008   #9
Robbo71's Avatar
With reference to wod's picture, stick your inclinometer on the motor body and adjust the bolt so that it reads 90-53.43=36.57.
Then the dish tilt would be adjusted and the whole assembly swivelled round the pole to give max signal on 1W, whilst the motor was sent to 0.3 degrees east.
Old 20-03-2008   #10
wod
Originally Posted by r1chard06 View Post
do you no were i could get a good ground stand for 1.2m dish
there's quite a few places like satcure that do the ground stands.
make sure you buy the 76mm/3inch pole version as the jaeger 1224 motor is better on that size pole, as i tried it on 2 inch and would not recommend it.
Old 20-03-2008   #11
My System: Gibertini 125cm, SMART Titanium 0,2 LNB, motorized, Manhattan Plaza, SS1 card
Supermount SMR-1224 zero (highest) position ?
I've just bought a SuperJack SMR-1224
My question:
Are there any simple method to "reset" it ?
(adjusting to the highest, ie.: the "0" position)
Thank you,
Balazs
benko5009 is offline   Reply With Quote
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
