help needed were to get a ground mount/stand
Thread Tools Display Modes
Old 20-03-2008   #1
My System: triax 90cm dish echolink 888 recever diseg motor
hi all looking to buy a ground mount/stand only place i found selling them
sells a 1 meter ground stand for £180 76mm but surely a 1m ground stand is a little small for a cm 1.2 dish anybody no were i can get 1 around same price or cheaper just a bit bigger
r1chard06 is offline   Reply With Quote
Old 20-03-2008   #2
My System: Channel Master 1.2m, Vantage VT-X221TS CI, Technomate V-Box II, 18" Superjack actuator
I have a 1m ground stand and its more than enough. It would allow you to see any visible satellite. Remember the az/el mount, polar mount or 1224 motor are attached to the centre of the dish so that leaves it 40cm clear of the ground when the dish is at 0 degrees elevation.
I would be more concerned at that price!
michael01707 is offline   Reply With Quote
Old 20-03-2008   #3
get ya point
so a 1m would be fine but other than satellite superstore for £139 plus £20 for extra feet plus postage £12.95 dont no anywere else i could get 1 from
Old 20-03-2008   #4
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
This supplier may have something suitable -
_www.jwhardy.co.uk/shop/pages/pl_ant_brackets.html
__________________
Llew is offline   Reply With Quote
Old 20-03-2008   #5
I had a quick look at this forum's sponsors and card mania have a 3" heavy duty ground mount for £61.99 with UK delivery but it says out of stock. I have a non penetrating roof mount which uses 4 patio slabs to weigh it down and means you don't need planning permission as it is not fixed to my property. I got this from Sat Europa for £126.50 with delivery.
Old 20-03-2008   #6
My System: Force T90, 1.2m Andrew, Triax TD64, Triax 17x6 Mutiswitch, Promax Prolink-4C Spectrum Analyser
You might want to look at:
_http://www.blake-uk.com/page/commercial_sat_mounts/commsatpatiomounts
SAT/3P is the one you're after I think
kubo is offline   Reply With Quote
Old 20-03-2008   #7
re stand
hi the blake one woudnt be from blakes in sheffield would it
Old 20-03-2008   #8
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
brymar in leeds have them for 69 pound on their website
_http://www.brymar.co.uk/acatalog/Satellite_Installation_Kits_25.html
you could give them a ring to see what they have, 01977 689079
Old 21-03-2008   #9
Mod and septic resident
Channel Hopper's Avatar
If it really is to be installed on the ground, get some 3" steel post material, flatten the end and drive it about a metre into the ground.
Alternatively get some additional angle iron and borrow an arc welder.
__________________
Old 21-03-2008   #10
joselin's Avatar
My System: none
do any of your mates work for a scaffolding company ?
joselin is offline   Reply With Quote
Old 21-03-2008   #11
no but i no were there is a nice trafic signal laying around wich looks right diameter and i no a welder
Old 21-03-2008   #12
Traffic light posts are usually 4.5"
(But road signs........)
__________________
Old 21-03-2008   #13
You are correct.
Old 21-03-2008   #14
Scaffold pole is usually 48.3mm and the CM 1.2 needs a 76mm pole
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
