best dish | |
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you want something which will not move, then a dish with a heavy steel bracket like a Gilbertini or channel Master on a 3" mast with actuator, or heavy duty 36v motor will do the trick. If you are using a budget dish on a DiseqC motor and 2" mast, then in extreme conditions, it may move.
__________________ | |||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | I've always wondered if there's a way to adapt the motor arm to the dish bracket with a bolt through method to stop possible slippage. | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I've not yet had a dish bracket move on a DiseqC motor arm, but have had the motor clamp move on the main mast, as the clamps on some DiseqC motors are not that strong. There is of course the potential for the nylon gears in the DiseqC motor to strip in severe conditions. @ Den123, Has your dish moved in the past?
| | #6 | ||
| Regular Member Join Date: 03-02-2007 Location: UK exeter
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12 | hi yes it moved last week in the bad winds we had its moved agian last night when the wing got up again so now on 1d west digi tv keeps breaking up i have checked the bolts last week for tightness den123 | ||
| | #7 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | The motor clamp doesn't have the best grip from what I've seen, it's got a small type 'V' section but not sufficient enough. May be a bolt through arrangement through the motor clamp and main mast. I did look at doing something but wondered if it would weaken the main structure. Also can easily see how the nylon gears may strip in very strong winds. Saying that, ( touch wood ), I have the same dis motor in an area open to the wind and have had no movement at all. Bang, click, stripe ![]() | ||
| | #8 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | den123, you have the option to fit a polar mount with actuator motor to the gibertini dish and think this would be better in your situation. also i move my dish to face the wind side on which helps | |||
| | #9 | |||
| Broadcast / RF engineer Join Date: 20-02-2006 Location: SE Wales UK
My System: 3.7m & 1.8m Prodelin, 1.2m Andrew, Loads of receivers, Orbit & showtime & AFN. | I would say the same thing as rolf has said here,
