0.4 degree movment on motor from reference
Thread Tools Display Modes
Old 26-03-2008   #1
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Out of interest, why does my Technomate receiver not move from reference to Thor and remain at zero after usals set up.
My long is 1.2 West. When I tell my motor to go to reference (zero) and then to go to Thor, it doesn't move. It should technically move 0.4 Deg East. (1.2 - 0.8 = 0.4)
The dilemma is my previous receiver of which I have just swapped out did make a movement of the difference between my long and Thor.
Could this be:
1. my previous receiver had 0.8 Thor and the new receiver has 1W Thor. Would this new movement of 0.2 degs be so small that the motor will not move anymore.
The system is working fine by the way with no problems, it's just I am interested to know.
Cheers
sg2100a, Technomate 5200D USB, previous receiver was a Topfield 5000ci
Old 26-03-2008   #2
rolfw's Avatar
I think if it were a quality 1.2m dish or bigger it would be critical, but probably isn't with an 80cm.
__________________
Rolf
Donate
Old 26-03-2008   #3
Information Exec
Just found it strange how you get the movement difference between the two receivers.
Old 26-03-2008   #4
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM1500CI+Super & TM5200D receivers, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
I imagine that it is because of
If you designate thor as 0.8 degrees west in your receiver instead of 1.0 west you will see the dish move slightly.
Rolfw is also correct, the larger the dish the tighter the beamwidth. The smaller the dish, 0.4 degrees, becomes insignificant in receiving a strong transmission.
Parky
Park Royal is offline   Reply With Quote
Old 26-03-2008   #5
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
I think the explanation is that your new receiver like mine has Thor at 1W by default, so the motor is only turning by 0.2 degrees. I maybe wrong but I think you would have trouble seeing this at the motor end.
Whereas 0.4 degrees bewteen 1.2W and 0.8W would be easier to spot.
You could always make another sat position for 0.8W or redesignate 1W to 0.8W as per Park Royals suggestion, you should see it move a bit then.
Robbo71 is offline   Reply With Quote
Old 27-03-2008   #6
Information Exec
Makes sense, cheers
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
