Whats the best diseqc motor ?
Thread Tools Display Modes
Old 27-03-2008   #1
keano's Avatar
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife !
Guys in just over two years my 3rd diseqc motor has now packed up, it will not go past about 12.0w no matter what I do.
Checked everything and all looks OK.
I should have kept 36v arm and mount.
My current dish is 110cm and I am wondering if its this that is killing all these motors.
I have gone through a stab motor and two superjacks now.
I am prepared to get a smaller dish maybe a triax88cm.
So come on who can recommend a good motor or should I just sack it and get one of these wavefrontier dishes ?
Cheers
Keano
keano is offline   Reply With Quote
Old 27-03-2008   #2
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
If you do go for an td88 after all, if it's any consolation, here in the Midlands, I can pick up all the usual satellites with no problem. I was originally going to fit a 110 on to a diseqc motor but decided not to. I thought the added weight may kill the motor after some time,,, that's not to say that has happened in your case of course
Old 27-03-2008   #3
SkysNotTheLimit
My System: Octagon 318, 1.1m Triax, dish and Orbital Disecq Motor,plus all other stuff
Motor
I have used the Orbital Diseqc motor for 3 years at my house in Dover , it handles the winds off the channel fine, I am on an orbital 90cm dish.
The gears/cogs inside apparently are not plastic like most.
Not bad price either.
andyw37 is offline   Reply With Quote
Old 27-03-2008   #4
rolfw's Avatar
If you are sticking with DiseqC, then consider a Fracarro Penta 85cm Aluminium dish (great performer) with a Moteck SG-2100, or perhaps one of the metal geared motors if you are in an exposed location.
__________________
Rolf
Donate
Old 27-03-2008   #5
Robbo71's Avatar
My System: Technomate TM1000D Receiver. Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
I have a Triax 110cm on my poor STAB HH-90, it seems to be surviving OK so far.
Robbo71 is offline   Reply With Quote
Old 27-03-2008   #6
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
after my experience with diseqc motor i hate them as it has given me nothing but hassle.
anyway people rate that darkmotor as rather good, as it has metal gears and they say it will take up to 1.4m dish which they must be aluminium dish
Old 27-03-2008   #7
rolfw's Avatar
I've heard the sellers of that motor say that they rate it, but no actual independent users, I just get the impression that it is perhaps being hyped, a little like the Technomate was when it first came out.
Beside that though, my Moteck has been up for near on five years now and has performed faultlessly for that period, in a very exposed position with an 85cm dish.
__________________
Rolf
Donate
Old 28-03-2008   #8
keano's Avatar
Thanks guys, looks like I will try and get a motor with metal cogs in side.
This latest fault happened after we had those strong winds last week and when I got on the roof last night there was a lot of play on the arm of the motor.
Might try a 88cm triax, I'm sure that a 110cm dish in a exposed location is not helping.
Just hope triax will pick up viasat ok.
Old 28-03-2008   #9
wod
what dish is it as if its the 1.1m triax they still do polar mount for it so that would be a wise purchase instead of the diseqc motor
think you have been lucky, mine hasn't even lasted a year and i'm getting shot of it soon as they are just rubbish.
Old 28-03-2008   #10
Has it given you trouble with a 110 or 88
Old 30-03-2008   #11
wod
satellite man, if you refering to me then yes i think i've just had a faulty motor from the start and not realised this.
keano, just thinking you thought of trying the jaeger smr 99 36volt h2h motor with that dish ?
Old 30-03-2008   #12
rolfw's Avatar
Go for the Fracarro, better performance and the Aluminium version is pretty light in comparison.
__________________
Rolf
Donate
Old 30-03-2008   #13
keano's Avatar
Only thing I found with 36v motor/arms is the noise they make and thats why I switched to diseqc a couple of years ago.
I don't really want to lose my 110cm dish because I can get 26.0e with this.
I have seen the new Technomate motor on Ebay which has had the hard plastic cogs inside replace with metal ones.
Old 30-03-2008   #14
Keano,
If it helps, I can say I have absolutely no problems receiving 26.0e with a Triax 88 even with a small amount of rain, it's still there. The only time I lose it is when it is totally dropping it down. I am in close to N'ton
Old 30-03-2008   #15
PSB
Satellite Head
PSB's Avatar
My System: Traxis DBS 3500 Matchbox Pro USB receiver 90cm and 1.8m dish
Winner of the "Most Enterprising Installation Of The Year" award
I am now into my 5th year using the MIGHTY SG2100 motor here in the USA. I live in Minnesnowta and use a 90cm Hot Dish with it! In all those years the motor has never missed a beat. 12" of snow? NO PROBLEMO! This bunny just keeps on going!
I am a LICENSED satellite installer here in the USA and I would LOVE to say the Euro STAB motor was good, but alas I can't EVERY one I have ever seen or worked on has BA C K LA S H.
PSB is offline   Reply With Quote
Old 31-03-2008   #16
keano's Avatar
OK quick update,
I have come home from work early and spent the last hour taking the 110cm televes dish down and to be honest I am not surprised I am on to my 3rd diseqc motor in 2 years this dish weighs a ton, nearly fell of the ladder getting the thing down.
Reading the info here I have just ordered from site sponsors, High Def. A moteck diseqc motor and some funny shaped dish a 85cm fracarro high gain.
Suppose to be as good as a 1mtr dish.
I not expecting the fracarro to give me 26.0e or 7.0w ( v Beam ) but if everything else is OK then it will fine, peace of mind for me too, when we have them high winds I can't sleep at night worrying about the 110cm televes dish bashing and banging about.
I'll let you know how I get on when I have set it all up.
Old 31-03-2008   #17
dasteelman's Avatar
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card
I found that the latest version of the technomate (with metal cogs) is quick, less noisey and very impressive
__________________
Nice but Dim
dasteelman is offline   Reply With Quote
Old 31-03-2008   #18
The Moteck seems to be a very popular all rounder motor and it's faster than some other motors. You have made a wise choice Keano.
Old 01-04-2008   #19
keano's Avatar
To be honest I was so close to getting the new technomate with the metal cogs and at the last second pick for the moteck.
Mainly because of our American friend PSB saying his has been up and going 5 years.
If I can come back on here in 2013 and say the same thing I will be a happy man.
Old 01-04-2008   #20
wod
strange i've had lots of hassle with my moteck sg2100a motor, think i've had one out of a bad batch as not heard of people having the issues that i have.
i'm avoiding diseqc all together and going 36volt
i would like to hear how the penta dish performs up north though as i will get one if they are good reception wise up here, it would fit nice on my jaeger smr 99
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
