Replacing LNB (Newbie Q) | |
| Member Join Date: 01-02-2008 Location: Near Colchester
My System: Sky Digibox, Zone 1 Dish. |
!Newbie Alert! Ello All, I have a Zone 1 Dish which was installed about a year ago by a Sky Contractor, it has a Thompson single LNB. I have the necessary bits, Quad, Cable, F Connectors to replace this in order to connect up a PVR when the BBC Freesat recievers go on sale - I'm going to do it myself as I have all the bits The only questions I can't find an answer for is regarding the skew of the LNB (hope thats the correct term) in East Anglia (Near Colchester) what would this be set to and the other Q it has a cover which can slide down over the connectors - is is advisible to still waterproof the connections? Thanks | ||
| Regular Member Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | 1) I would still waterproof using tape 2) I would personly adjust the skew of the lnb as you see fit. Someone will probably give you the correct settings of the skew, but it would be very easy to mess with it yourself and see which optimimum signal you get
__________________ Nice but Dim | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If it is a Sky minidish quad LNB, then the skew is preset within a small adjustable range, trial and error will do it, move to one side and check the quality on the digibox, then progressively move it across to find the best spot. If you want to make sure that the connections are moisture proof, you can just smear some vaseline around the plug, top and bottom.
__________________ | |||
| Information Exec Join Date: 07-05-2007 Location: Midlands - UK and Lanzarote - Canary Islands
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Astra 2 is so strong that it wouldn't matter too much what setting you set the skew on but for being accurate, you want to set it to position 3. You can just slide the cover down but I always put self - algamating tape on the F connectors to be sure. Hope this helps | ||
| | #5 | ||
My System: Sky Digibox, Zone 1 Dish. | Thanks for the help, One last q though which I've thought of after looking out the window at the dish (and at the neighbours dish), the new LNB has the plastic thing to hold it to the dish, will this be set to the focal point of the dish? My dish only has a very short arm (if this is the correct term!) compared with others nearby! | ||
| | #6 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | The plastic LNB holder is a universal item that should come supplied with the Quad. It's used to fit the LNB to different types of zone 1 sky dishes. | ||
| | #7 | ||
| Enigma1 Dreamboxer Join Date: 24-09-2006 Location: Wolverhampton. West Midlands
My System: Dreambox DM7020, Global 1m Dish, MTi 0.2dB Twin lnb, Technomate SG2200 motor. Technomate TM9100 Super, Global Orbit 90R Dish, Mti Twin 0.2dB lnb, Moteck SG2100a motor. Dreambox 600PVR. Rover DM16C Digimax & Rover DL4 Meters. | Make sure you move the dish angle up slightly to compensate for the weight of the quad lnb ![]() The weight of the lnb has a tendency to pull the arm down a little more than the single lnb does. If the dishes elevation is set up badly it could make the difference between you getting a signal or not getting one. Make sure you mark the dish first before you do anything so you have a reference point to go back to if anything goes wrong ![]() ![]() Nano
__________________ I'm a Satellitehelp refugee ![]() | ||
| | #9 | ||
| Supporting Advertiser Join Date: 22-10-2007 Location: Colchester in Essex
My System: 80cm Motorised with a Phoenix Apollo CI+MC. Diablo Cam 2.3, Freesat & Cable TV. | Well done, pretty easy ay!
__________________ www.cdtronix.com Tel:08454 750 192 Sky, Freesat, Dishes, 0.1db LNB's, XXX Viewing Cards, Cams, Quality Coax Cables | ||
