LNB & Feedhorn Question | |
| Member Join Date: 05-04-2008 Location: Sweden
My System: 150 Cm Focal Nokia Dish. Topfield TF-7700 HSCI. LNB: Invacom C120 single. Feedhorn: SMW-XM 140 Cables: Edison >120 |
Hi, I have some problems with the reception on my motorise sat-system, after a while of watching..the picture jumps out of signal. It seems to me there is some interference between the V&H signals? I have the Invacom Single SNF-031 C120 LNB combined with an older SMW XM-500 Feedhorn. Does anyone know if these combination could be the cause of this problem? Thanks | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Thh XM-500 is a circular feedhorn ideally mated with an SMW dish. This is almost certainly why you are experiencing polarisation problems. How have you coupled it to your Invacom? Llew | ||
| | #3 | |||
My System: 150 Cm Focal Nokia Dish. Topfield TF-7700 HSCI. LNB: Invacom C120 single. Feedhorn: SMW-XM 140 Cables: Edison >120 | Yes the XM-500 feedhorn is circular and for focal dishes, but so is the Invacom SNF 031 Single LNB. The flange is C120 and it is fitted to either the older XM-500 or the never SMW XM 140 without problem. What i get out from the spec of the feedhorns F/D. there shouldn't be a problem really? What i don't get is what combination of feedhorns and LNB are compatible then? The Invacoms feedhorn are to thin in diameter, but of course a handyman like me could always fix that ![]() I just want the best reception for all channels Any recommendations of compability? Thanks | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | So you had no problem fitting the feedhorn to the Invacom? I found my XM-604 4-hole fixing didn't align with the Invacom perfectly, and had to leave one screw out. Still a good seal though on the O-ring. Don't know the best feedhorn for your PF dish, only have offset ones. | ||
| | #5 | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Your XM-500 hasn't got the integrated RHC/LHC integrated depolariser by any chance, as I imagine this would affect performance? _http://www.smw.se/res/pdf/feedhorn1.pdf Robbo
__________________ | ||
| | #6 | |||
My System: 150 Cm Focal Nokia Dish. Topfield TF-7700 HSCI. LNB: Invacom C120 single. Feedhorn: SMW-XM 140 Cables: Edison >120 | I was thinking of fitting the XM-140 with the Invacom C120 SNF-031. What LNB,s would be better then Invacom SNF 031 if.. i'm after a better performance for all freq ? My current dish gives me about 38 Eirp in KU-band from where i live.If i could get it better in performance with a better feedhorn and LNB it would always be appreciated.The F/D on my dish is 0.4. Amplifing 11.3Ghz is 43,3dbi. The offset dishes is said to get better performance then focal ones. How much difference % are e talking about here with the same size dish? Is a wider feedhorn like invacoms give better reception&performance if fitted correctly then the XM-140? I thought i might get it to fit my feedhornholder with some special made adapter. Thanks Last edited by radical; 06-04-2008 at 10:22 AM | |||
