Teleco magic sat 2002aInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Welcome to the forum ![]() Have you contacted Teleco support? _http://www.support-telecogroup.com/telecogroup/teleco/en/supporto.htm Some info here as well: _http://www.motorhomefacts.com/forum-printtopic-1-15380-0-0-asc-viewresult-1.html | ||
| Member Real name: Karel van Zon Join Date: 17-05-2009 Location: Netherlands
My System: Teleco Magicsat 2002a | During my last holiday in Spain I accidently changed some settings of my Teleco Magicsat 2002a. These settings are not in the usermanual and 'no one' seems to know what the values should be (Teleco Italy points me to the dutch importer and the dutch importer tells me it is to old and they don't no the values). The settings are the 'search criteria' (my set is in dutch so maybe the translation is wrong...) of the ASTRA 19E satellite. As a result of these bad settings the dish can't find the satellite anymore... Two sets of values should be entered: Name Sat: ASTRA 19E Criteria 1 (1 and 2) Values: Frequence: .... MHz Polarisation: H (H/V) Sigal: Y (Y/N/---) Mode: Analog (Analog/Digital) The Hotbird satellite values are untouched and operates fine so the set is technical fine?! Here the settings for the hotbird so you technicians can see what values are needed `------------------------ Name Sat: EUTLS 16E Criteria 1 Frequence: 11322 MHz Polarisation: V Sigal: Y Mode: Analog ------------------------ Name Sat: EUTLS 16E Criteria 2 Frequence: 10729 MHz Polarisation: V Sigal: N Mode: Analog ------------------------ Any help would be greatly appricated since almost all dutch channels are on astra 19e!!!!! | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Am I to assume that the bottom table is supposed to read 19E as 10,729 is not a frequency on 16E, but it is an analogue channel on 19E and the middle one 13E? Any chance of changing the menu language to English, as most of the words are similar, but a couple are not so obvious? Sigal would I presume be set to yes | ||
| | #5 | ||
My System: Teleco Magicsat 2002a | Thanks for the reaction to start with! The bottom two sets (EUTLS 16E criteria 1 and 2) are setting were already in the set and that satellite is found. The ASTRA 19E worked until I started messing with the settings and that satellite isn't found anymore... It is a bit difficult to change the language to english because the caravan is still in Spain (we were there in may and return in august). I am trying to get a good suggestion, print it out and take it with me when we return! | ||
| 2002a, magic, sat, teleco |
