multivision on dreambox??Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Regular Member Join Date: 30-06-2007 Location: Brussels Belgium
My System: DB7000S HDD USB2GB; 2CM120+Norsat4106Afor HH&7707AforVH on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E | @abr1 Your cable is resonating with the Dreambox input stage at the resulting IF frequency (1912mhz) corresponding to Multivision (11662mhz). I have had the same problem and it was sorted out by changing the cable, to any other cable, not necessarily a better one. Try autoupdating with Ushuaïa tv. and using Cccam 2.0.8 on your actual version of Gemini. @ Keano I need a CM corrugated feedhorn and an Inverto flange version if they are still there. Looking through the throat of the feedhorn, do you see a circle or a rectangle? | ||
| | #27 | |||
| Member Join Date: 04-03-2008 Location: Staffordshire
My System: dreambox 7000s panasonic plasma 42" samsung dsr9500 samsung lcd 27" |
i have tried it this morning after further adjustments of the lnb and now getting 64% enough to get a picture with regards to the feedhorn i have sent Keano a PM a week ago i am very interested and awaiting his reply many thanks for the input m8 | |||
| | #28 | ||
| Regular Member Join Date: 15-01-2004 Location: Manchester UK
My System: 2.4mtr Channel Master Dish, Fracarro Penta 85cm Dish, 64cm Traix Dish with 4 multi LNB'S Sky HD, Dreambox 800, Dreambox 500, IPBOX 250, Sky HD and a mad wife ! | Guys sorry I've not been on line for over a week. @canofan my feedhorn inside is round. @abr I will pm you later when I get home from work. | ||
| dreambox, multivision |
