multi lnb holders ? questionInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 12-06-2005
My System: ft1000mp tl922 ma5b |
hi all just getting back in to multi sat rx i used to have a 36v h-h motor but this time i was just thinking about 1 dish and a 3-4 way lnb bracket i was looking at the triax one...i would think 19 in center 28 and 13 either side...or in some cases i have seen 13 center and 19 28 to one side ,which would you recommnd ??? one last question... the triax multi holder looks like its not possible to put an lnb holder in the center position ?? becouse of the screws/bracket , surley this is not a good deisign ??? cheers thanks for reading gbsurf n.w.england | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Depends on how the dish performs, for example I have done Triax centred on 19e with 28e/13e as offsets. Now take Raven dishes as an example; you can centre on 13e with those as of the design | ||
My System: ft1000mp tl922 ma5b | thanks for that...how did you get the lnb bracket on the center ? if you look at the pic there are 2 screws there ??? so it looks like you cant slide the holder to that possition any ways i will probs go for a raven setup ..with 19 center thanks | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Just have to slide it as close to centre as possible. | ||
| | #5 | ||
My System: ft1000mp tl922 ma5b | oh well i spose.. but it sounds a bit "heath robinson" i.e. not using the prime focus of the dish !!! ok ,in the market for a raven 70cm dish with multi bracket.. i have read some gud reveiws about this set up on here... cheers | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | You could use either one of these dishes with brackets. | ||
| | #7 | ||
| Regular Member Join Date: 01-01-2000 Location: Rainham, essex
My System: 90cm gregorian 5way zone2 | being just east of london, i can get away with abit more, but mines just off centred 19.2e http://img.photobucket.com/albums/v1...atsonzone2.jpg | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That's a Zone 2 minidish, so between 65 and 70cm across, slightly smaller than the Raven Gemini 70cm. | ||
| | #10 | ||
My System: ft1000mp tl922 ma5b | i actually have one of those..i think some where !..but is the multi bracket home made ? ,or is there one available to fit it( i think its a zone 2 channel master) i think the lnb holder kinda slots in to the end of the arm cheers | ||
| | #11 | ||
My System: 90cm gregorian 5way zone2 | Its a Multi Feed Holder for up to 4 LNB's for a Gibertini dish, attached to abit off alu L section cable tied to the original dish arm, to get 2@s more distance away from the dish. Google "Multi Feed Holder for up to 4 Lnb" the top links where it come from. the 5th lnb holder on 5e is a electric drill grip handle thing cut down and cable tied on, had a spare lnb so thought i'd use it .and yes zone2 dish | ||
| | #12 | ||
My System: ft1000mp tl922 ma5b | thanks for that p i am just gonna buy a raven gemini 70cm dish with the mulit bracket for east and west... centerd on 19e does every one think this will be big enough for me ..all they way up here in sunny cumbria.. ciao cheers | ||
| holders, lnb, multi, question |
