Multi LNBs vs Motorised dish
Old 16-05-2008   #1
My System: TM 5400-CI pointing at Hotbird 13E
I am relatively new to the satellite scene and after a few months of enjoying HotBird @13E on my fixed mini-dish, I would now like to get freesat as well @28E. I just wondered if someone could advise me as to whether go for a bigger fixed dish (80 cm?) with a multi LNB bracket pointing at 13E and 28E or instead go for a motorised dish. What are the pros and cons of each option? If you do know a good installer in West Berkshire, please give me a shout! Many Thanks
alacatar is offline   Reply With Quote
Old 16-05-2008   #2
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, Gibertini 104cm, Invacom SNH-031, 12inch 36v Actuator, Technomate Vbox-II, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 42E to 30W, Tecatel 1.35m fixed on 28e
Multi-LNB system is a good option (13e, 19e & 28e) but for not much more money you could do well in a budget motorised system
satelliteman.
Quick Reference Motor Installation Guide also > HERE
An Installers Choice
Old 16-05-2008   #3
Robbo's Avatar
My System: TM6800HD, TM1000, TM5200, TM2200 motor, Triax TD110 dish + Fibo 90cm.
For just 13E and 28E, you are better off with a fixed dish, but most of use would never be satisfied with just those two.
With the average 80 to 90cm ish dish you can normally have up to 20 degrees and up to 4 satellites with a standard DiSEqC 1.0 switch. The advantage is fast zapping, i.e no waiting for the motor to work its way round.
The advantage of a motor is obvious- more choice, at the expense of time when it moves.
The best option is to have a fixed and a motorised dish, but that is being greedy.
Robbo
Robbo is online now   Reply With Quote
dish, lnbs, motorised, multi
[IMG] code is Off
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
Content Relevant URLs by vBSEO 3.3.0
