Thanks for the input guys.
Originally Posted by Robbo71 The smaller the dish, the more chance you have to align it by luck. |
I will stick with the minidish then, or would using the non-elliptical
Skyware LNB make it harder anyway?
Originally Posted by Robbo71 But really, you have to be methodical in your approach. Set the elevation about right, then slowly sweep the dish from one side to the other. If you get nothing, alter the dish elevation and repeat. |
That was my basic approach, but not having a braket to keep it steady really isn't helping, I will try attaching a 4 axis spirit-level to the arm.
The main problem is the inaccurate / delayed software signal meters, I might have more luck with the beeper.
There are just too many variables, my main problem is not knowing which are the important ones!
Originally Posted by HB13DISH You still need an HD receiver as the two PC cards mentioned are only for SD. |
I know they aren't DVB-S2 tuners but I think some FreeSat decoders only have DVB-S tuners so it looks like BBC / ITV HD
(and maybe C4 & 5 when they turn up) will be sticking with DVB-S for the time being.
I've got the software side of things covered, I helped beta test the first wave of H.264 stuff back in 2006 when the trials first started.
I couldn't even get 20fps on my Athlon FX 2.8GHz rig at the time, now I get less than 5% CPU usage with my 8800GT using DXVA!
I'm a complete noob at setting up a dish but I've been playing with DVB software for a while...
Originally Posted by HB13DISH Or the Dreambox HD if you can wait until the piggy bank is overflowed. |
lol, it's got to be Dreambox, with any luck I should be able to take a hammer to Mr Pig in a few months...
I thought about one of those DM500 mini-dreamboxes but I don't think they do one with a DVB-S2 tuner yet?
Probably best to get a "proper one" anyway.
Thanks again for you help guys, I'll keep you posted.
Cheers,
Nick
