Satellite System for Spanish ChannelsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
| Member Join Date: 05-03-2008 Location: wiltshire, marlborough
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | Jesus Christ! guess who is back... The more I understand the less I understand... does it make sense? the receiver says that I find satellites Astra1, Astra2a2b and sirius 2.3. However I am searching for info in sirius 2.3 and I can not find anything (for example I can see StarTV UKR). My biggest doubt is, is it possible to perfectly locate a satellite (for instance Astra1 and being unable to get Hispasat30W?) I thought once you locate one, the other ones automatically will come out.... (naive, me?) I have no idea why but the receiver change the name of Hispasat to 330 and even though I feel it is good positioned, does not pick up any channels even though the first bar percentage is high (the other one is 0) any ideas? and thanks again!! | ||
| | #27 | |||||
I think when you find a satellite you should check here to see if what you think you have got is what you are seeing on the screen. Too little or too much declination is a distinct possibility By the way it would help members to help you if you put details of all equipment in your profile | |||||
| The Following User Says Thank You to Topper For This Useful Post: | izaceci (11-07-2008) |
| | #28 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | many thanks Topper! Obviously it makes sense everything that you mentioned, however I think everything is oriented and perfectly straight, and somehow not getting it... My dish is a 80cm Technomate and the receiver a Opticum 3000L. I do not recall right now the name of the motor, but seems to be working ok I will keep on having a look Many thanks for your help! | ||
| | #29 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | Hello all, ok, I have just updated my equipment details, hope it helps thanks! | ||
| | #30 | ||
Can I suggest you post some photos of the lnb and dish as we may be able to spot a problem | ||
| | #31 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | ok thanks Mr Topper. I will try to make them later today. Thanks again and good day to all! | ||
| | #32 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | hello all, as promised mr topper, I attach some pictures of the dish. I reduce the format as much as possible so I hope it is ok Comments will be appreciated as usual, thanks! | ||
| | #33 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi again, ![]() Are you getting Thor OK? I may be wrong, as I don't know what your dish offset angle is, but the dish does look like it is tilting up a bit more than it should do, when I'm on Thor, the dish face is at 5 degrees. Also the elbow bracket is not the best choice, T&Ks and a scaffold pole would be much better, are you 100% sure the pole at the end is 100% vertical.? | ||
| | #34 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | hiya mr Robbo71. thanks again for your response. Regarding Thor, at the moment I can not get it but because my receiver it is quite crappy...(by the way,..someone could suggest a better one, which I could also set up with keys and stuff...[which I will be asking later on in another chapter... ]) and it only gets around 2000 channels, which is already what I have with astra2a2b, sirius and hotbird. Do you reckon I should try to set it up first to Thor? my latitude is 51.427° and longitude -1.728° but I am not sure if I am doing it right as I can not put a minus figure in the receiver when I use usals...If I get channels,...is there any way to know where is your limit? Maybe I am giving you all a headache and it is not possible to get Hispasat or other channels i believe the pole is 100% vertical if that helps, would anyone attach some pictures or their dish so perphaps I can see the light? millions of thanks | ||
| | #35 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Any old crappy receiver should get Thor, even yours. There are lots of FTA channels on there, including BBC World on 11325H. And Yes, that is where you should attempt to set up the dish. Not all receivers have a minus sign, actually I don't know if it is common or not, but anyway, on mine you have to set a W or an E. If you put our lat and long in, send it to 0.8W or 1W, tune to 11325H, then monitor the sig quality. Then adjust the dish elevation and swivel the whole lot roun the pole for max quality. Also I would recheck the elevation of the motor to make sure it is correct. Also, you have to be sure that the pole is vertical, as it will never track the arc if it isn't, unless you are very lucky. I can't do a picture of my dish as it is too dark now, but I measured the angle of the face and it was 5 degrees whwn on 1W, but this is dependent on the dish. If you look through the members Pictures section, you should find some pics in there. There is also one in Rolfw's guide and satelliteman's ( see the stickies). The limit is basically when the dish looks at the ground (around 60 or 70 degrees), but if the dish is low and there are obstructions, it would be less. I live in a housing estate with relatively close together houses with my dish about 4ft of the ground, and I can get 42E to 30W. So what you want should be achievable, as long as you dont have an obstruction. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | izaceci (16-07-2008) |
| | #36 | ||
I second all that Robbie has said, one thing is certain, in your posts you have admitted you have not followed the procedure correctly by not setting up on your due south satellite. You are thus lucky to have what you already can receive. Robbie is also correct about the bracket, basic moments of inertia principles dictate that the rotational stress on the bracket is far too high for the strength and small size of the material used since the motor is set away from the bracket. The sheer forces on that bracket mean that if it does not snap soon, if will in the next strong winds we have. Those brackets were never designed to be operated with motors. Finally, it looks to me that the lnb is fixed too far forward (towards the dish) in the sleeve, have you fine tuned this setting to achieve maximum signal on a given channel, or have you just put it in there? | ||
| | #37 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Important to also make sure the dish is centre on the motor shaft. On that motor there is a thin line running down the shaft. Line this up to the centre of the dish. If it's not spot on, it will throw you off the arc as the motor turns | ||
| | #38 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | thanks satelliteman, the motor line is definetively line up to the center of the dish. if not, I probably will have to go to the optician... ![]() thanks again for all your support and kindness to share all your knowledge about this. I hope I am not being too painfull... good day! | ||
| | #39 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | thanks again Mr Tooper. at the very beginning I did not follow the procedure as I was completely lost and even though the forum is extremely good and helpful, at the beginning can be a little bit difficult as it has quite a lot of info to manage. as far as I understand, I set up the dish to the south, and I did make sure everything was straitgh and line up. I tried to install it with the automated search of the receiver, and I picked up some channels. After the help of some of our colleagues from the forum, I did as they suggested and I tried using USALS (but then the negative signed, gave me a problem, as I could not insert it in the receiver, or do not know how). What I meant with my crappy receiver, is that only pick up about 2000 channels, and it is already full!!!, so what I have to do now is delete those channels/satellite, and try again to pick up THOR, as suggested. Hopefully after that I can achieve Hispasat, however I can already see spanish, italian, polish, german, russian, french,... but not the freesat english ones.. Regarding the pole, at the moment I will prefer to leave it like that, as I already have few arguments with the boss..., and I prefer not to be hunged up by it... (however when it came the installation kit, it was saying the bracket was suitable for a motorised dish up to 90 cm)...maybe in the future I'll change it!Regarding the Lnb, thanks for that, I will look into it, as that can be definetively something I have got wrong, even though I moved it few times to check up the signals in the receiver. Once again, many thanks for your help and patience!! GOOD DAY TO YOU ALL!! | ||
| | #40 | ||
Frustration, frustration, frustration is my surname!! after winning the fight with my wife , and setting up the dish with T&K brackets, checking everything is vertical and aligned, now... nothing! I barely can get anything [I still try to find out what satellite I am getting checking the channels.. ] and before I got plenty of channels in astra2a2b, astra1, hotbird, and sirius (not hispasat... ) [spanish, italians, french, germans, polish...]now it seems that I am getting dutch channels and few english, which makes me think is the one for freesat (... I can not believe I forgot which satellite name is now! basically the only change I have done is that I have raised the dish about a metre as I thought this might help to avoid roof houses when trying to reach hispasat 30W. I tried to keep the same elevation, but... any other ideas? I will try to finish with this once and for all during the weekend THANKS for your suggestions!! | ||
| | #41 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | So what your saying is, you had it all working fine but since you raised and replaced the brackets; it no longer picks up all the satellites ? | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | izaceci (01-08-2008) |
| | #42 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | All, you need to do mate, is to go through Rolf or satelliteman's guide again, step by step. Now you have the pole nice and sturdy and vertical, motorise to Thor as before, then move the motor round the pole and adjust the elevation angle of the dish, for max quality on 11325H, and you should get everything back. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | izaceci (01-08-2008) |
| | #43 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | yep,... basically that's it, sad isn't it? | ||
| | #44 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | honestly I did that but no way I can get Thor or BBC on 11325H which should be the strongest signal. I am going to give it a try this weekend again, and let you know, but believe me that Rolf guide is my bible thanks and nice weekend to you all! | ||
| | #45 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | not enough time to do anything this weekend... anyway, hope everyone had a good weekend!... keep you posted | ||
| | #46 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Try 12341V (national Geographic) instead, you may have more luck. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | izaceci (06-08-2008) |
| | #47 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | here i am again!, sorry I have been unable to put in practise your advices, but with this crappy summer that we are having, I have not been in the mood to have an accident in the ladder... Anyway, yesterday,(not rainy day), I tried all day to oriented the dish. Just when I was running out of light (and faith!), I managed to get some signal and some channels It seems that I can see pretty much the same channels than before changing the wall installation to T &K brackets. Now I am going to investigate which satellites I am catching, as honestly I am not 100% sure. One thing I know for sure, and it is that Hispasat seems to be out of my league... i have printed from _http://www.lyngsat.com/europe.html all the astra and hotbird info, as I am not sure which one I am getting, so with the list of all the frequencies I guess I will find out or go nuts! once again thanks for your help!!!! and have a nice loooong weekend! ;0) | ||
| | #48 | ||
My System: Technomate 80cm dish Digipower motor. Diseqc H-H Motor SG-2100 PremiumHD LNB. Input: 10.70-12.75 Ghz. Output: 950-2150 Mhz. Noise 0.3db antiblock Receiver: Opticum 3000L | Hello gents I am afraid after all my efforts I can get channels from hotbird and astra. (spanish and polish) However I can not get the english freesat ones and the ones from hispasat Is this as far as I can get? Would it be better if I change my receiver? (as the one I have got is few years old and not updated). would it give me more chances? Thanks | ||
| channels, satellite, spanish |
