Receiving Cyprus Channels
Thread Tools Display Modes
Old 05-06-2008   #1
jammy1's Avatar
My System: Octagon SF118, 60cm dish
Ok, I'm very new to all this, so please be patient!
I'm trying to get as many free to air Cyprus/Greek channels for my mum.
She has an east facing balcony on the 14th floor of a block of flats. Which satellite should she point to, what equipment is needed (cheap and simple, she's very old) and who can fit it?
She lives in NW3.
Please help! This would make her very happy.
jammy1 is offline   Reply With Quote
Old 05-06-2008   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
If you just want free stuff Hellas Sat 2 39E is probably the best bet - it gives you a decent choice of radio services as well:
http://www.flysat.com/hellassat.php
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Analoguesat is online now   Reply With Quote
Old 05-06-2008   #3
jammy1's Avatar
Is that the best for Cyprus? There are a lot of Greece channels, but not all the Cyprus one.
What equipment would I need? Can I get away with a discreet dish?
Old 05-06-2008   #4
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Cyprus will be ERT and RIK sat. I have done plenty of them. All you need is a 60cm facing Hellasat @ 39e, a FTA receiver and your away. Trnasponder 12606H, 30000, 5/6
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 05-06-2008   #5
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Yes, the 12606H transponder looks like it has a few Greek FTA channels on it.
Judging by the footprint _http://www.lyngsat-maps.com/maps/hellas2_f1.html it should be possible with a Sky minidish. I will check later with mine.
Receiver wise you just need a FTA satellite receiver, there's no point in spending too much on it. I think one of the site sponsors was selling a Golden Interstar for about £35, don't know what it's like though.
Robbo
Old 05-06-2008   #6
Site administrator
There arent many Cypriot channels carried on satellite. Basically its RIK Sat or nothing.
There are a handful of channels with Cyprus as their base but broadcasting in Arabic though!
http://en.kingofsat.net/find2.php?po...rd=&ordre=freq
__________________
Analogue forever!
Old 05-06-2008   #7
Site administrator
Robbo
HellSat is an easy catch on even a 43cm zone 1 dish on a good day, although Id want a 60cm zone 2 dish for rain fade.
__________________
Analogue forever!
Old 05-06-2008   #8
Information Exec
I have tried a Zone 1 on 39e Robbo and it's receivable but signal quality was marginal. A Zone 2 will cope with no problems
__________________
Old 05-06-2008   #9
Robbo's Avatar
If a zone 1 minidish were sufficient, you may be able to get away with it mounted below the level of the handrail, since you are going to be pointing roughly at 51 degree angle from the wall.
EDIT:
AS and satman, you posted while I was still thinking/typing
I think I'll try it anyway as the OP is closer to me than you Midlanders.
Old 05-06-2008   #10
jammy1's Avatar
What's a zone 1 / 2 dish?
The walls at the side of the east facing inset balcony face north and south, so the dish will be attached there.
Is there someone who could fit it for me?
Old 05-06-2008   #11
Robbo's Avatar
They both look a bit like this:- (see below)
The zone 1 are about 50 odd cm wide, the zone 2 are about 70cm.
They are what Sky use, the larger ones are for the weaker signal areas up t'north.
Ahh, then, you should be OK, on the south facing one.
There is an installer list on the front page I believe. Shouldn't be too much of a problem to fit at all, you don't fancy a bit of DIY then?
http://www.satellites.co.uk/installers/
Old 05-06-2008   #12
jammy1's Avatar
Well, I could give it a go, but how do I get the directions and elevation right?
Old 05-06-2008   #13
Robbo's Avatar
I always use _www.dishpointer.com
Just enter you postcode, and the sat you want, and it will tell you the required azimuth and elevation.
And if you zoom into the Map, to your building, you can see where the yellow line points to, and point the dish that way.
Of course adjustments will be needed to actually pick anything up, but you can use the signal quality meter on the receiver, to wiggle the dish around for maximum signal quality.
Old 05-06-2008   #14
jammy1's Avatar
Ok let's say I've grown some balls, I'd still need a list of all the equipment I need, including cabling, and somewhere to buy it all from.
Any suggestions?
Old 05-06-2008   #15
jammy1's Avatar
What's this kind of stuff like?
Ebay 140237225316
Last edited by Robbo; 05-06-2008 at 05:55 PM Reason: removed direct link to ebay item
Old 05-06-2008   #16
Robbo's Avatar
I'm not familar with that make or receiver, one of the others may be.
Technically it will do the job though, it is a Digital FTA satellite receiver, just what you want. And at that price who's complaining.
Incidentally, I decided to try my zone1 minidish on 39E, looked at the transponder 12606H and getting a good signal at the moment, 71% in fair whether, which is only 1% lower that one of the main channels I get from Eurobird1 (Tiny Pop). So if discreetness was the utmost priority I think you would get away with it, but since these are the only channels you are after really, for peace of mind the Zone 2 would provide it.
(see screenshot below)
As for equipment, you could either pick it all up from Ebay
Zone1/zone2 minidish and LNB
wf100 coax
Receiver.
Or check out one of the site sponsors for example, Southern Satellite has the TM3100D and both minidish sizes. CDTronics also does a full FTA kit, but you may want a dish upgrade.
Robbo
plus any fixings, I have used coach bolts and rawlplugs on my minidish, but for extra strength you you should use sleeve anchor bolts.
Old 05-06-2008   #17
Information Exec
Good result Robbo for Zone 1
__________________
Old 05-06-2008   #18
jammy1's Avatar
WOW, thanks for all your effort. I've found a complete kit for 90 quid that looks like it will do the job.
What do you think?
Ebay 310054948378
Last edited by Robbo; 05-06-2008 at 06:59 PM Reason: Remove CLICKY direct link to ebay item.
Old 05-06-2008   #19
Robbo's Avatar
Yep it should do. The receiver make is not given though.
I'd be more inclined to go for a well known brand if I were going to pay that much for it. The TM3100 as mentioned before is about £40, and the Dish/LNB is about £30, good cable (wf100) or the Televes equivalent is usually about 50p a metre.
BTW, the site admins prefer that no direct links to Ebay items are posted, just the word Ebay and the item number.
Old 06-06-2008   #20
jammy1's Avatar
Oops sorry for posting Ebay stuff... Could you advise somewhere that sells that receiver and a 60cm dish for a good price? I can't seem to find a good shop.
Thanks in advance!
Old 06-06-2008   #21
Information Exec
Try here
__________________
The Following User Says Thank You to satelliteman For This Useful Post:
jammy1 (23-06-2008)
Old 23-06-2008   #22
jammy1's Avatar
Ok, I need more help PLEASE!!!
I have fitted the satellite, connected the LNB and receiver, but I am unable to get a signal. In fact, the lack of signal strength doesn't seem to change even when I detach the cable from the receiver.
1) How accurate does the dish have to be?
2) Is there anyone willing to physically help me in setting this thing up (I will pay!)
I have an Octagon SF118.
I'M DESPERATE!
Old 23-06-2008   #23
Robbo's Avatar
The dish has to be accurate within a degree or so in both aziumuth and elevation.
Could you post up a picture of how you have it set up right now. There might be something obvious wrong.
Also tell us the receiver settings, and how you are going about trying to find a signal.
Old 23-06-2008   #24
jammy1's Avatar
This is how it's setup, I didn't think to take an actual photo whilst I was there this weekend (see attachment)
What receiver settings do you need?
I was trying to line it up using the information from _www.dishpointer.com and then moving it up, down, left and right to see if the signal strength would move. I got nothing.
MR SOUTHERN SATELLITE --> Does the LNB you sold me require power?
I tried all the available settings on the SF118 installation screen (on and off) with no joy.
I really want this thing for my mother, and I am willing to pay for a home visit.
Old 23-06-2008   #25
rolfw's Avatar
The setting which most first timers get wrong is the elevation setting, they normally point the dish way too high, for 39 East, the dish face will appear to be pointing slightly downwards.
Also check the fitting of the F connectors, see my little pictorial tutorial here, the LNB does require power, it is delivered via the coax cable.
Also make sure that your receiver is set on a frequency which carries an easy to receive channel, 12606 H is a good one.
__________________
Rolf
