Is an 80/85 cm offset dish good on a diseqc motor
Thread Tools Display Modes
Old 08-06-2008   #1
My System: satellite
hi,thanks for your helps guys.i wanna know that is a 80 or 85 cm offset dish can be good on a diseqc motor? can i have good signal of satellites in the normal motor azimuth range ? can i have all channels with a good quality ?
thank you so much.
Parsasat is offline   Reply With Quote
Old 08-06-2008   #2
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
thank you so much.
Yep, an 85cm dish is OK on a DiSEqC motor.
No you will not get all channels from all the satellites on your arc. Consult _www.lyngsat.com and the footprints, to gain a rough idea of what you might receive.
Robbo is online now   Reply With Quote
The Following User Says Thank You to Robbo For This Useful Post:
Parsasat (09-06-2008)
Old 09-06-2008   #3
Arrow
hello,thank you so much for your help friend.i know that we cant not have all channels in my round arc.but i mean that can i have those channel which i had them with a 90 or 100 cm ordinary dish steady dish with a 80cm offset dish on a diseqc motor ?
thank a lot.
Old 09-06-2008   #4
Robbo's Avatar
Probably not, NO, as the dish is a bit smaller, but it depends on the performance of the dish.
Generally though, if set up correctly, you would get the same on a motorised dish as you would on a fixed dish (using an identical dish).
Parsasat (10-06-2008)
[IMG] code is Off
Forum Jump
