Symbol Rates | |
| "Satellite Expert" Join Date: 01-01-2000 Location: Kernow
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface |
Why do some receivers have symbol rates as high as 45000, whilst others go no higher than about 31000? Is there any advantage in having the greater range? wolsty
__________________ wolsty | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
It would seem that for normal viewing anything above 30,000 is pretty well unnecessary on most of the satellites using KU band, I guess that a symbol rate higher than that would be used for high quality single channel per transponder applications. Rolf
__________________ | |||
Its all to do with the manufacture of the receiver Some tuners have only one filter in them (the fiilter works in a similar way to the user as a bandwidth filter on analogue equipment - 18 / 27 MHz etc) to allow the receiver to filter out unwanted stuff The ceramic filters of commercial or subsidised boxes are limited to the higher symbol rates of 18 - 45000 Ms/S and so cannot be used to receive the SCPC broadcasts - this is why the older receivers (and to some extent BSKYB stuff may not be good at finding everything, even though there are further restrictions in the firmware and OSG) Newer receivers have a dual circuit of filters that has switching between the old limits and the new of 1 - 22 Ms/S You will not see the switchover in operation, and there is no point in restricting the upper limit of 45 by the manufacturer as it would limit overall sales There are some broadcasts up there that do have higher symbol rates than 300000
__________________ There is a very fine line between "hobby" and "mental illness" | ||
Typo - that should have been 30000 Just woken up and its not my usual keyboard
Similar Threads | ||||
| Symbol Rate. ? | newtosat | Digital systems | 5 | 07-09-2007 08:13 PM |
| bit rates.....help!??! | littlehelp? | The Meeting Place | 5 | 11-06-2006 10:56 PM |
| low symbol rates on SkyStar2? | Wombatter | Satellite PC Card Systems & Internet by Satellite | 4 | 10-05-2006 01:19 PM |
| Decimal point in Symbol rate | girly | Receiver software, international Section | 5 | 29-12-2004 02:12 AM |
