Skew problem with Fortecstar LNB FSKUVN and Icecrypt 0.1db single LNB
Old 01-09-2008   #26
My System: MVision satellite receiver
I have a Fortec Star Quad LNB which i hope to install on Tuesday....Will it require the same angle as the single LNB variant ?
MalM is offline   Reply With Quote
Old 01-09-2008   #27
rolfw's Avatar
Real name: Rolf
Not sure, but check the skew markings on the top of the LNB first, bear in mind that they probably don't make their LNBs, merely brand them, so the quad may be from a different manufacturer.
Rolf
The Following User Says Thank You to rolfw For This Useful Post:
MalM (01-09-2008)
Old 01-09-2008   #28
My System: 1m Motorised Technomate dish with Technomate 5400 CI+ Receiver
As ive wrote on another thread, i bought a Fortec Star motorised system from maplin (£99) with this exact LNB and i am having terrible problems to pick up more than about 7 channels (when i hoped to pick up several thousand!)
durhamwasp is offline   Reply With Quote
Old 01-09-2008   #29
rolfw's Avatar
Real name: Rolf
Try changing the skew as mentioned above.
Rolf
Old 01-09-2008   #30
Just moved the skew around anti clockwise, immediate difference - picked up a few hundred channels on 28.2E (basically all the Sky channels)
Same problem exists with finding nothing at any other satellite, such as 19.2E
Old 01-09-2008   #31
Robbo's Avatar
Real name: Mark
If the Skew is roughly right for one satellite it will be roughly right for all the others with an H-H/polar motorised sytem.
Old 08-09-2008   #32
My System: Fortec HD Passion+ 65cm Dish and 'correctly skewed' LNB supplied in Maplin kit.
Just out of interest, as a newby I bought the Maplin HD kit referred to in this thread. As there were no dish instructions included I contacted Maplin who pointed me at their site for a download.
The diagrams bore little resemblance to the dish I had in the box so I contacted Maplin again and was advised to contact Fortec direct.
As they are located at Sheffield United's football ground and I'm not a football fan I emailed them instead...3 times with no response.
I pass their place every working day and felt like paying them a personal visit however during a browse of their website I noticed that none of their dishes on offer looked like mine leading me to the fairly obvious conclusion that the dish in my kit was not a Fortec dish.
However, since it works I have decided not to pursue the matter any further.
Strat is offline   Reply With Quote
Old 15-09-2008   #33
The Quad LNB from Fortec Star does not require you to move it at any angle other than straight at the dish so if thats a help to anyone you can rest assured it was easy to install and get working.
Old 27-09-2008   #34
Former member
snap's Avatar
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter
It may not be relevant but the single LNBF manufactured by Televés required skew at the same angle as the Fortecstar LNB FCKUVN.
They were orange in colour- don't know if still made.
snap is offline   Reply With Quote
Old 19-10-2008   #35
My System: At the present only SKY
fortec problems
rolfw, pure coincidence, a friend bought one of these few days ago, problems with signal looked on this site and amazed at the fact that the LNB was mounted anti clockwise, thank you very much. Also can you recommend a good (basic) sat finder the one which tells you what sat you are recieving as i do a lot of touring (motorhome) it can be a real pain sometimes trying to get SKY, i dont need too much technical info on it.
thanks again keith
Originally Posted by rolfw View Post
This is the LNB FCKUVN, which Maplins sell with their Passion HD package.
The customer had tried to set up the dish himself,but had problems, so I dropped in to do the final alignment.
With the LNB in the usual Skew position for Astra 28.2E, I was getting abysmal quality readings and a very flat spectrum, so I moved it further around until the spectrum improved, but found I was on the opposite polarity.
Well the picture attached is where I had to put it for perfect skew, have included a red line to show where I would have expected it to be.
keithj is offline   Reply With Quote
The Following User Says Thank You to keithj For This Useful Post:
swimmer (21-12-2008)
Old 06-12-2008   #36
My System: FORTEC STAR PASSION+ Satellite Kit (Maplins).
Thumbs up Busy weekend now
This thread looks just like the info I was after, To get some better signal & quality levels on my Maplin system.
So thats my quiet weekend gone.
sooty736 is offline   Reply With Quote
Old 29-12-2008   #37
My System: Fortec Star Innovation
Thanks so much for this. I was beginning to dispair and now its all sorted. I have the Maplin Innovation setup but I have not put the motor on yet. If its working on Astra with the tweaked LNB, what is the best way to setup the motor? Should I set it up on Astra with the LNB as it is and then as it scans around the LNB skew will move correctly?
Any help welcome.
akg101 is offline   Reply With Quote
Old 29-12-2008   #38
Robbo's Avatar
Real name: Mark
No, the lnb skew for a motoised dish should be set to zero. On a fixed dish, you will have it twisted round a bit to suit 28E.
Adjust the lnb skew for max quality signal on your nearest to due south satellite.
Old 29-12-2008   #39
satelliteman's Avatar
Real name: Paul
....or change the LNb and have it done with
satelliteman.
An Installers Choice
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
akg101 (30-12-2008)
Old 29-12-2008   #40
Robbo's Avatar
Real name: Mark
I have come accross these LNBs a couple of times now, and they're not really a problem. There are the usual graduated scale markings on it showing where zero skew is.
The Following User Says Thank You to Robbo For This Useful Post:
akg101 (30-12-2008)
Old 30-12-2008   #41
Thanks again.
Old 01-02-2009   #42
rolfw's Avatar
Real name: Rolf
Also same problem with Icecrypt 0.1db single LNB
Here's a couple of pictures of how it needs to be skewed for Astra 19.2 from Berkshire.
The skew for that satellite from this location should be 15 degrees clockwise, but as can be seen from the photo, what is actually required is around 40 degrees anti-clockwise.
The LNB does have a feint scale on the top, but many users will miss this and assume that the cable connector should be at the bottom and more or less vertical.
Skew problem with Fortecstar LNB FSKUVN and Icecrypt 0.1db single LNB-icecrypt_package_p2012021-jpg   Skew problem with Fortecstar LNB FSKUVN and Icecrypt 0.1db single LNB-icecrypt_1_p1312014-jpg   Skew problem with Fortecstar LNB FSKUVN and Icecrypt 0.1db single LNB-icecrypt_2_p1312015-jpg   Skew problem with Fortecstar LNB FSKUVN and Icecrypt 0.1db single LNB-icecrypt_3_p1312019-jpg
Rolf
Old 01-02-2009   #43
guest
Posts: n/a
Thanks for that clear and unambiguous illustration of the issue (Issue as opposed to problem - just a minor trap for the unwary, but so easily resolved).
Old 01-02-2009   #44
rolfw's Avatar
Real name: Rolf
Thanks, had forgotten to add that there is a scale on the top, but it is easy to miss.
Have now added it.
Rolf
Old 01-02-2009   #45
Real name: Paul
Nice info Rolf
oh no, what dish is that ?, lol
satelliteman.
Follow us on
Old 01-02-2009   #46
rolfw's Avatar
Real name: Rolf
No idea, it was a bit flimsy though, the customer bought it all as a package on the internet, it does however work OK.
Rolf
Old 16-02-2009   #47
My System: Fortec Star Innovation HD, HH100 DiSEqC Motorised, 90cm Dish.
Rolf what a great bit of information, I was loosing hope with the whole lot, it took hours to set up the Maplin kit, the bracket pole was inadequate for the massive motor clamp, as were the wall fixings, then I spent the whole weekend getting to grips with finding satellites and the arc, after hours of trying to find 28.2 and the UK channels, read your thread and hoorah- 98% and I'm holding all the positions on the others, fingers crossed!! Now for getting the box customised for what I want! Cheers
bobble22 is offline   Reply With Quote
Old 16-02-2009   #48
BombedOne's Avatar
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc.
This LNB seems to be direct clone of Turkish made Next & NextStar YE-122 LNB, which also has same problem.
check picture here:
_http://www.digium.net/urun.php?urun=goster&id=33
BombedOne is offline   Reply With Quote
The Following User Says Thank You to BombedOne For This Useful Post:
rolfw (01-03-2009)
Old 01-03-2009   #49
satbadger's Avatar
My System: 90cm Fortec star offset dish. Fortec star motor. Fortec star 0.2 FCKUVN LNB. Technomate 6900 Super Manhatten Plaza ST550 Reciever
Thanks to everyone on this site (Cheers Guys) I now get a signal from the FCkIN LNB. I currently have it on its faint zero marking.
My question is assuming I twist it for best quality and signal values on say 1 degree west Thor, will it need to be tweaked again physically for say 28.2 or Hispasat when the dish drives round? Will I just have to compromise for all Sats?
Thanks in advance.
satbadger is offline   Reply With Quote
Old 01-03-2009   #50
rolfw's Avatar
Real name: Rolf
No, should be fine for the other satellites, as the motor skews the whole dish as it travels the arc.
Rolf
fortecstar, fskuvn, kit, lnb, maplin, passion+ hd, problem, skew
[IMG] code is Off
