trying to setup motorised dish
Thread Tools Display Modes
Old 30-06-2008   #1
teide_ian's Avatar
My System: Home-Amstrad Sky Digi-box on 60cm dish. Bar - Pace Sky English Digi-box and Grundig Sky Eire Digi-box linked to a 2.4m Channel master dish with a single dual output LNB. Digibox for ART network on 90cm dish. Digibox for Digitalalb subscription. Di
I am trying to setup a motorised dish, i have put in the longitude and latitude figures and setup to due south which satellite i have tuned into 7W Nilesat. I have then sent the motor back to 0 degrees then back to 7W and altered accordingly.
But when i send it to look for say 28.2 the motor is either going back to 0 or opposite direction any ideas why.
Thanks.
teide_ian is offline   Reply With Quote
Old 30-06-2008   #2
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Originally Posted by teide_ian View Post
Thanks.
Check limits.
Haven't installed a motor dish in Canaries but assuming you have a decent size dish, I would say 15W was a better ref satellite to set up on
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 01-07-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Thanks.
Please clarify dish size and motor type, and if using USALS or not.
Long and lat are only necessary for USALS through Diseqc1.2.
Robbo71 is online now   Reply With Quote
Old 02-07-2008   #4
teide_ian's Avatar
The dish is 1 metre and the motor is a mot-sat3 with diseqc 1.2 i also setup the longitude as 16.35 west and latitude 28.07 north. I have entered these in the gotox section in the dreambox 500s.
Thanks for replies.
Old 02-07-2008   #5
Robbo71's Avatar
The only thing I can think of is maybe you have put the longitude in wrong eg positive instead of negative, as I've no experience how well the gotoX function works on the Dreambox, it may be image dependent.
You could always try it without the gotoX, just use Diseqc1.2 alone and store the positions manually.
Robbo
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
