sat motor help | |
| | #26 | ||
| Member Join Date: 27-06-2008 Location: n.ireland
My System: technomate 54c | | ||
| | #27 | ||
| | #28 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Nothing wrong with the USALS settings from what I can see. Are you having problems locating 5W at set up? > Goto 'motor control' > Press 'goto reference' ok, this will take the motor back to zero. > At this point - go outside and make sure this dish is straight and centre on the motor shaft and LNb is straight and vertical. > Back to the receiver and at the top, under satellite, change to 5W Atlantic Bird 3 and then goto > The dish will move 1.1 degree. Then if using the receiver signal screen to set up then select a transponder on 5W and adjust the dish together motor around the pole bracket and the dish elevation to find a signal. > lock up. Simple if you do it just as above. Paul Satman
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | nistleboy (07-07-2008) |
| | #29 | ||
My System: technomate 54c | hi all i rang the technomate guy today he told me it could be the coaxial from the techbox to the motor might be faulty and it might not be getting right sygnal to motor.so im going to fit new cable tom and see if he is right ,hope so. | ||
| | #30 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sounds unlikely, if you are getting good signal strength and quality as shown in the picture above, the cable is probably not at fault.
__________________ | |||
| | #31 | ||
My System: technomate 54c | hi paul will try this tom k ,before i put up new cable it sounds quite promising. i think my mum loves this sat rec ,she has not seem me this much in years. . thanks paul ps hope its sunny tom been shit weather over here recently | ||
| | #32 | ||
My System: technomate 54c | hi rolf thought it sounded silly but thought i may as well try it. if it does not work tom ill phone the guy that i bought it and ask him to replace. thanks rolf | ||
| | #33 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Yes do as per post#28 and it should be a done job
| | #34 | ||
My System: technomate 54c | hi paul thanks very much for your help went to motor and then to ref and then to 5w. it went just a click or so used sat meter to get good synal and locked up. then sent to astra 19e and it went straight to it mate.then sent to hotbird and again sent to it.i cant believe it was ready to give up a couple of days ago. i would just like to thank all involved in helping me and im going pay some money to site . its the best 200.00 i ever spent just looking forward to football now lol. ps paul could you send me your paypal will send you some funds to buy some beers. cheers everyone | ||
| | #35 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Glad your up and running eventually nistleboy ![]() Thanks for the offer but would be happy for any donations to be put towards to running of this forum ![]() Regards Paul Satman
