Fracarro Penta 85cm VS Triax 88cm
Thread Tools Display Modes
Old 03-07-2008   #1
Irregular Member
compufunk's Avatar
My System: DM 600 PVR with HDD. Latest Gemini Image, Moteck SG2100, Fracarro Penta 85 dish, + some puters
Hi Folks,
I know this has been done to death, but I'd still like to have your opinions
I've settled on buying one of the above in aluminum, and I'd like to hear what any of you have to say about them,
Whichever one I decide to install will be mounted on a motor on the roof of a bungalow,
@ Rolfw, I know you tested Fracarro Pent 85cm, Do you have any comparison info with the Triax 88cm?
Regards.
C,
compufunk is offline   Reply With Quote
Old 03-07-2008   #2
rolfw's Avatar
Yes, unfortunately I couln't test them side by side, as by the time the Fracarro unit arrived, I had no more Triax dishes in stock and my wholesaler had stopped stocking them. The only think I can say, is that the Fracarro performed significantly better, particularly when looking at satellites like 16 East, with from memory an improvement of 4db or better in signal strength.
__________________
Rolf
Donate
Old 03-07-2008   #3
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
and that's a doubling of power so to speak.
dB=10 Log and all that, can't find the formula........
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 03-07-2008   #4
Irregular Member
compufunk's Avatar
Thanks Guys, From what I've read, the Fracarro Penta seems to be worth the few extra notes it will cost.
Old 03-07-2008   #5
rolfw's Avatar
Even if it performed the same, I would still go for it, as it has a much better build quality and is more compact.
__________________
Rolf
Donate
Old 03-07-2008   #6
Irregular Member
compufunk's Avatar
I just ordered the Fracarro Penta from one of the site advertisers,
Thanks again,
regards
C
Old 03-07-2008   #7
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
the triax dish has an iffy dish elevation bracket which is annoying, you get the right setting and slowly tighten the bolts and it loses the setting which is not good
i would not recommend the dish, stay away in my opinion as they are too thin and flexible
i wonder how the penta dish compares to the 90cm gibertini dish , any one compared them ?
rolfw, you installed that fibo dish yet ?
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
