LNB: silly question | |
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It goes where the signal quality is best (trial and error), it also needs skewing to suit the satellite you are pointing at, about 7 O'Clock for Astra 28.2 from Heathrow.
__________________ | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | As Rolfw says, the best position is where the signal on the box peaks at it's highest percentage of Signal Quality. Personally I start by pushing it toward the dish, then sliding it backwards, but if you have a strong enough signal you shouldn't have to do too much adjustment... ![]()
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | ||
| Member Join Date: 30-06-2008 Location: heathrow
My System: FS4200, iss 70cm dish,single passion lnb | Okkey cokey chaps the 7 degree you mention rolfw ,is that anti or clockwise?The okkey cokey Thanks for yer elp, no doubt more silly questions to come ![]() | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | 7 O'Clock when looking at the dish from behind the LNB. ![]()
| | #6 | ||
| Roider Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | But what if your installing the dish at 12 o clock? Ill get my coat.................... ![]()
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| | #7 | ||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | It must be me but I didn't click str8 a way with the above text. To make it clear anyway for those like me, LOl ...... 7 O'clock looking at the dish from standing in front of it ![]() but don't do it on the half an hour ![]() | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | LOL, nobody works through their lunch two hours. ![]()
| | #9 | ||
My System: FS4200, iss 70cm dish,single passion lnb | Call me thick ,but are we talking about degrees here not o,clock because 7 o/c the lnb would be nearly upside down and can i use my watch as a guide, ive heard that 1 second is equal to 6 degree is that right? I have found out the skew is 13.4 so looking at it from the front "facing dish"i would have to turn it anti-clockwise,Am i correct?thanks for your help guys ![]() | ||
| | #10 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Stand in front of the dish as if you would be blocking the receiving incoming signal. Imagine or picture a clock face. When the little hand reaches 7 O'Clock, This will be a a turn in the clockwise direction ![]() | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | portly (05-07-2008) |
| | #11 | |||
My System: FS4200, iss 70cm dish,single passion lnb | ![]() | |||
| | #12 | ||
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! | Probably not helpful in the slightest, but LNBs will work upside-down (looking from the front of the dish), I had (still have actually!!) a heyuuuuge Grundig Twin LNB on my indoor Hispasat (30w) dish, and the dish had to be pretty close to the window aswell as being low in order to pick up the signal, so the LNB had to be inverted with the cables at the top in order for the dish to be low enough... ![]() But anyway, yes, the Cable/Socket is the "Little hand", pretend you're the LNB and look towards the dish, turn the LNB clockwise to 7 o'clock, tighten up the nuts/screws and you're done, well, for the LNB skew you are... ![]()
| | #13 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | now if you were using a MTI supreme 0.2dB, that would throw you off.... ![]() | ||
| | #14 | ||
My System: FS4200, iss 70cm dish,single passion lnb | Well the dish is up and working, it went pretty easly, took about 15mins ,ive got 90% signal strenth and 70% signal quality would you say thats pretty good.I am going to replace the coax and perhaps the lnb in the future, but coax first as it is crap rg6u, i wouldnt even use it for cb use, if it were 50ohms infact my rg6 50ohm cb cable is far superior ![]() now one has to find somewhere that tells me whats on and were | ||
| | #15 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Well done ![]() | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | portly (06-07-2008) |
| | #16 | ||
My System: FS4200, iss 70cm dish,single passion lnb | And theres one thing ive found out is: i can also get turksat 1b and arabsat 2b at a pinch , signal levels are poor but can still view the channels | ||
