yous must be sick of all these questions | |
| Member Join Date: 04-07-2008 Location: scotland
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve |
hi ive read all the tuts and downloaded all the files and seen all the utube movies on how to set up a motorised dish ,and hey am enjoying it still ,but have never managed to get anything apart from 28.2, i set up at first an"L"shaped bracket and stuck it on my old s*y location,i didnt think i was getting a good reception so i changed it to t&k bracket ,mouted it above the roof and made sure it was plumb on all sides ,set dish and motor to all the settings and started to play around ,lol its been 2 weeks now and all ive manged to get is 28.2 ive moved it this way and that and still no results with any other satalites | ||
| Super Moderator Join Date: 10-12-2004
![]() | Hi father ted, it would help a great deal if you could please provide us with a lot more information. Size/Make of Dish. Make/Model of Motor. Make/Model of your receiver. What method have you used to set up your motor? It would also make it easier if you updated your profile, to include a little of this information, especially what receiver you have. | ||
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve | really soz about that its a Moteck 2100a diseqc motor with a 1 meter dish (mesh)the system i have is called openmedia(it does say this in my profile,maybe yous dont know this system lol) it is a twin tuner system based on 500 dreambox it has one tuner for cable and one for sat(can i say that lol)it has a pli ilolite image on it .i set my motor using multimap co-ordinates which is 56 north 3.7 west ,i have been able to get only as i say 28.2 nothing else,im here to learn so if i can tell yous anymore that will help feel free ,i must be getting addicted to climbing ladders | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Welcome to the forum father ted Well you thought you had got away with it but you have not, back up those ladders right this minute... Oh OK then it has gone dark... good job you do not live in Iceland ![]() The reason you have only got 28.2 East is because you forgot to fit the motor Oh Ok then, try to imagine an arc in the sky this arc runs from 60 East to 60 West approximately. Ok now as you are based in the UK Your due south satellite is more than likely 1 deg West or 5 Deg West, take your pick but 5 deg West probably is better for you, whichever you choose that is your due south satellite. Therefore the top of the arc of satellites that you can see is either one of the two. There having settled on either one or the other, within your stb that is your zero degrees, now you need to loosen the mast clamps and swing the whole motor assembly round to zero degrees and clamp it. That is the top of the arc where your lnb is vertical and any other position either side is lower as it is further around the arc. From then you should be able to use Disecq or Usals to move forward and find other satellites.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| The Following User Says Thank You to Topper For This Useful Post: | father ted (05-07-2008) |
| | #5 | ||
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve | ok came off nite shift and went back up to have a wee look lol anyway yous know am having problems not only with the dish but understanding all this new talk (but am getting there)well at this moment i only have 28.2 but when i went to check where the motor dial was, it said 5 deg east?now surely that aint rite?i sent motor far west then to zero then to far east then to zero again i then reset motor to zero again and then went to menu and goto fuction which was 28.2 and again it went to it and bbc1 came on (by the way its a gr8 picture lol)went up ladder again and it said 5 deg east?these are some pictures of how its on at the moment | ||
| | #6 | ||
| Regular Member Join Date: 18-12-2004
strange ye can find 28!...try reset... Lat set on motor 'ok!' Motor set to zero Dish set to zero (approx 40) Lnb (no skew) Face the lot 'true south' forget tring to aim at any sats! go to stb and use yer remote select Thor 1 or 5 west FTA channel...motor will move look at the signal..then back up the ladder and tilt the dish 'few' degrees vertically upward to see any gain, try any other sat and slowly adjust the dish tilt if no further gain tight-up (sat meter would help...save all the dish tilts) hope this helps ![]() M8...just spotted yer prob!....Lat 56...yer Motor should be set at 34...see table at back of 2100a Manual Last edited by gerryl; 05-07-2008 at 05:40 PM | ||
| The Following User Says Thank You to gerryl For This Useful Post: | father ted (05-07-2008) |
| | #7 | ||
don't give up.... ...Dish Pointer (.com...do a google) will help with Lat...and show ye where all the sats are...! Last edited by gerryl; 05-07-2008 at 05:48 PM | ||
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes I agree, the latitude scale is on the other side of the motor (Moteck motors have both scales), the latitude has been set on the elevation scale by mistake. It concerns me also that you say you can only get 28.2 East, is that when moving the motor with the receiver? If it is, then you have missed out the most vital step and that is finding your nearest to due South satellite.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | father ted (05-07-2008) |
| | #9 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | A common mistake done by many...... including myself by rushing Don't forget the read the guides & tutorials and you'll crack it
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | father ted (05-07-2008) |
| | #10 | ||
| Member Join Date: 18-06-2008 Location: Scotland
My System: Eurovox quantum on a Technomate TM2200 motor and a 1mtr Dish with a MTI 0.6 LNB and have added a Technomate 1500CI+to my collection | Hi m8...its frustrating but worth it in the end.....did mine yesterday ...possibly 5 hours in total...check out the link...hope its of help My story here | ||
| The Following User Says Thank You to Dogs For This Useful Post: | father ted (05-07-2008) |
| | #11 | ||||
1 made sure that the dish,motor was all in line 2 i found south on a compass and turned the whole thing ,motor,dish on the pole to south(or near enuff) 3 i looked for thor and asked dish to goto thor and it traveled slightly one way then onto what i assumed was 1.0 west(am i right?) 5 tried to get a good signal on a meter manged to get it to go to about 9 on the scale ,and to about 10 while tilting the dish up and down (isnt that good?) 6 went back in to check signal on box and all i could get was and agc of 99% a ber of 100-500 and a snr of only 60% 7 am now thinking it mite be hardware fault or i mite still not be lined up properly (lol which doesnt surprise me ) 8 i have tried numerous images and all the same readings or near enuff............................................. .................................................. ........... ooooh forgot to say i still have 28.2 | ||||
| | #12 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | A picture of the dish/motor on zero might help. Have you done as the guide suggests?
| | #13 | ||
what setting are in yer stb...can you upload new motor channel list!...from another source. cause if you followed the above ye should be runnin...looks like yer getting 28 by pure error!...keep going its not dark yet | ||
| | #14 | ||||
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve | | ||||
| | #15 | ||
OpenMedia is Linux receiver comes pre loaded with a custom free-to-air neutrino or enigma image, you should be able to FTP channel motor list such as pet123...also much much more...please be careful where ye source yer images and 'other' files!...and make sure they are tested for OpenMedia as some image are generated for ONLY certain versions of Dreambox ! Last edited by gerryl; 05-07-2008 at 10:21 PM Reason: adds | ||
| | #16 | |||
| | #18 | ||
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve | rite back again ok no further forward have carried out everything yous have been saying 1 have now placed the whole dish on new t&kbrackets rite up to the gutter ,in fact is so far up it can swing right round without touching the roof.i was thinking that it was getting a weak signal 2 i placed a new pole ,2 inch scaffolding pole on the brackets 3 i managed (dont ask how) to get the dish, motor onto the pole ,by the way its plumb on all sides i even ran a plumb line to the floor and its spot on 4i lined the dish,motor and pole so that they were all in line and the back of dish was paralel to the rest 5i bought a new compass and made sure i found south 6 turned the whole thing around pole ,the dish, motor until it reached a mark i had done and checked with compass to south 7 i left it loose so could jiggle with it 8 took out meter and played with dish till i got a good signal on south reached almost 10 and tightened it up a bit keeping an eye on meter didnt go to far below 10 9 then i started to play with elevation of dish,manged to get it to 9 after a few tweaks here and there and tightend that up 10 went to box and tried one tweak to east ,then another and so on but nothing 11 then i did the opposite way so i turned it 10 times east so i done 20 times west still nothing 12i couldnt get the snr to raise above 60% so now am thinking problem with box 13 but i did get 28.2 14 never picked up any other sat and am thinking its a hardware fault(box its self) wot yous think?have i done all i can?? 15 my mrs is serving my meals through the bathroom window casue am up the ladder more than am in the house | ||
| | #19 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | When you found what you thought was thor, did you then scan it on the receiver to check that it was?
| The Following User Says Thank You to rolfw For This Useful Post: | father ted (06-07-2008) |
| | #20 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | OK up to point 7, then you should come down and send the motor to your reference sat and then align on that. If using 1W 11325h You are almost there and think the problem may be your not finding your ref satellite.... the most important part of the installation. No need to nudge the motor East or west once you are on your ref satellite, just scan and see. We will get you there
| The Following User Says Thank You to satelliteman For This Useful Post: | father ted (06-07-2008) |
| | #21 | ||||
| | #22 | ||
My System: just new , i have a 1meter dish, connected to open media twin unit (cable/sat)and this moment am a ladder fiend ,my wife sends meals up to me via pigeon but im loving the learning curve | ok ive been at this for a while now and still no joy lol but am loving the tips am getting soon ill get there and ill wonder what all the fuss was about ,question! i went to my mates the other day and he has a dish up and working but his motor is the opposite to mine ?is my motor up the wrong way?????see picture? | ||
| | #23 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No, your motor is the right way up, but your dish looks way to high in elevation.
| The Following User Says Thank You to rolfw For This Useful Post: | father ted (10-07-2008) |
| | #24 | ||
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Agree, exactly what I thought when I looked at it re the El. Your mate most probably has a stab motor of which is the other way round. The F connections should always be facing underneath OR down |
