How do you fit coaxial cable into a corner?
Thread Tools Display Modes
Old 05-07-2008   #1
My System: Wanting to setup syste to receive ART sports
My coaxial cable hangs slightly out from the wall, and I do not want to use those nail and clips things up the wall as place is rented. Anyhow, basically I would like to know how do you fit coaxial cable into a corner so that it runs up straight.
thanks for the read
Aidy
AidyB is offline   Reply With Quote
Old 05-07-2008   #2
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Mini trunking will do it (16mm). Paint or wall paper over
EDIT: for internal that is
have you tried pvc tape :
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 05-07-2008   #3
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
try some no nails sealant as i'm sure that would stick the cable to the bricks
Old 05-07-2008   #4
Rented mate so trunking out of question, well I could but its not to all tastes. Can I use pvc tape whatever that is, im sure its on *bay.
Would no more nails not leave a reasidue on the walls, or was that a joke :P
Old 05-07-2008   #5
Information Exec
external or internal..... it wasn't that clear
__________________
Old 06-07-2008   #6
lifes not a practice run
4dbennett's Avatar
My System: technomate diseq 1500ci+ ibm thinkpad
there are some excellent "velcro" wire/cable clips about now m8 try Wilkinsons, they have a few types in the phone/audio section, or on internet
regards dave
4dbennett is offline   Reply With Quote
Old 06-07-2008   #7
Its internal. I Like the vekcro idea now, cheers Aidy.
Old 06-07-2008   #8
Information Exec
I thought so as that's how I read it and then after thought you meant external
__________________
Old 06-07-2008   #9
Donate to this board
Park Royal's Avatar
My System: Smart lnb, 1m Gibby dish, Stab motor, TM1500CI+Super & TM5200D receivers, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
A small blob of "BluTack" every 6 inches should do the trick.
Or run "Pritt the non-sticky, sticky stuff" down the corner and press the cable to it.
Parky
Park Royal is offline   Reply With Quote
Old 06-07-2008   #10
My System: Sky+ Astra+Hotbird and Virgin broadband
try some clear silicone for the cable works a treat. or self adhesive mini trunking that wont require drilling the walls.
streetlighter is offline   Reply With Quote
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
