problem break up
Thread Tools Display Modes
Old 06-07-2008   #1
My System: technomate 6900 hd darkbox rev 2007 104cm gibertini dish. moteck 2100a with diseqc 12
problem break up
hi guys can anyone please help i have a sxy dish the signal is good have check it with meter when its on bbc its fine when its on true movies its crap break ups also break up on itv some times some channels are good some are bad but the signal is ok thanks what do you thinks the problem thanks
den123 is offline   Reply With Quote
Old 06-07-2008   #2
Amo Amas Amant Admin
Topper's Avatar
Mmmm
I would check signal strength again and if you can flex the dish in all directions to see if it improves. The cloud density was very high today with the storm clouds and this can lead to too much attenuation of the signal. Perhaps you would be safer to fit a zone 2 dish if you are using a zone one.
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 06-07-2008   #3
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Haven't checked the freq but is it within the DECT interference freq. I'm sureI seen this with true Movies B4. It could also be as Topper has suggested of course
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 06-07-2008   #4
thanks i have done all that have moved the dish to get the best quality could the lnb be knackerd seems strange that some channels are ok others not thanks
Old 06-07-2008   #5
Information Exec
Yes, I have checked it does fall within the DECT freq.
Have you a DECT portable phone close to the receiver ?
__________________
Old 06-07-2008   #6
no mate not got dect phone
Old 06-07-2008   #7
Information Exec
Worth a stab as that's the normal culprit
__________________
Old 06-07-2008   #8
ok thanks mate will try let you know]
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
