1.8 dish help needed please | |
| Member Join Date: 07-07-2008 Location: portsmouth
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football |
i have had a 80 cm dish for over a year and have just brought a 1.8 merte dish so i can pick up nilesat i live in portsmouth have done some reading and some post say i might struggle to pick up nilesat can some please help. | ||
| Roider Join Date: 23-07-2005 Location: S.Wales
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | What make dish is it? What lnb and feed are you using?
__________________ Roiders are like the sun, big, orange, and never stare directly at them | ||
| Regular Member Join Date: 05-10-2005 Location: UK.
My System: technomate 1500 strong 4375 pace digi box triax 1.1, triax 88cm | red rum, when i had a 1.6mtr dish i got the verticals and thats from hartlepool in the north east, so realy you should pick it up, possibly the horizontals as well | ||
| | #4 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | At a guess its one of the 99 quid Maplin dishes. (Horribly low quality and have a nasty tendency to buckle in winter storms!)
__________________ | |||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well if it is, then spend a few hours assembling the reflector, ideall on a very flat floor surface, one of our members RD100 has managed to get one to perform reasonably, but said that setup is crucial. The dish is i believed supplied with a standard LNBF, a C120 and feedhorn would probably produce better results. If it isn't, would be interesting to know which brand it is. ![]()
| | #6 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | it is a IRTE s.p.a made in italy i have order a c120 and a feedhorn and a v box 2 as the dish and moter is very old have been told this is what i need hopeing to get tomorrow to start geting it setup just hopeing it is big enough for nilesat so i can get the football cheers redrum | ||
| | #7 | ||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Look forward to reading the results Redrum, although I had the impression it was going to be a fixed system.... don't know where that came from ![]() | ||
| | #8 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | yes mate will let you know hope quite soon have you heard of the dish. cheers redrum | ||
| | #9 | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta |
if the motor is an actuator then you might need to change it for a new one. | |||
| | #11 | ||
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | the motor should look like this if the dish uses a polar mount | ||
| | #12 | ||
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | The IRTE is a very good dish. There is a matched feed horn for the IRTE, see if you can get hold of one. It will perform much better with the matched feed. -http://www.irte.it/I/a_csat.htm
| | #13 | ||
| Regular Member Join Date: 01-07-2006 Location: Alzira (Valencia)
My System: Technomate 1500CI Super, Vantage X221TS CI with Sly FTV card, Illusion motor, 1.2M Tecatel dish with invacom LNB | | ||
| | #14 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | yes wod it does look like that won when rain stops will try and set up let you know how i get on | ||
| | #15 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | set my 1.8 dish up and have pick up nilesat got all the showtime channels and sports channels signal strength is between 45 and 65 so i thing when it rains might not get a picture. | ||
| | #16 | ||
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | What feed horn did you use?
| | #17 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | not to sure but dont thing i change the feed horn just but the c120 on. i im bretty new had this so my sound a bit thick.my next thing is to get a viewing card or keys what is my best option look for key and could only find old one so i am guessing they dont come up very often can someone help. | ||
| | #18 | ||
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | So What feed horn did you use with the C120 lnb? Regarding the keys, just use the latest patch for your Technomate ![]() Dont you use a spell checker? ![]()
| | #19 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | I'm using the original feed horn that came with the dish. That's why I don't leave many posts as spelling and grammar not my strong points. (I get the wife to do it when she's about!) | ||
| | #21 | ||
My System: techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football | put in latest patch 27/6/08 but did nothing is there a new one or im i not doing some thing right. | ||
| | #23 | ||
My System: 1.2M & 90cm and 55cm Gregorian Dish`s, Dream box 7000,160Gb HD,7025 200gb HD, Vbox-II. SS2 Card. 42" Plasma tv. | Result then mate! Was not taking the piss about your spelling, its just that your post was a little hard to understand ![]()
