Motor suitable for a triax td110 | |
| Member Join Date: 19-08-2005 Location: Ireland
My System: Sky hd,sky + with multiroom, 1.1m dish on thor 1w for the moment with tm1500ci ,Panasonic viera 42' plasma tv |
Hi I am just wondering has anybody got any ideas about what kind of motor i need for a td110 in an exposed location on a 2' pole. Thankyou for any replys. | ||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | In an exposed position this still may not be enough. Polar mount possibly ![]() | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I certainly wouldn't advise putting a 1.1m dish on a DiseqC motor in an exposed position, you may be better off going for something like the Gilbertini 1.2m with a polarmount.
__________________ | |||
| | #5 | ||
My System: Sky hd,sky + with multiroom, 1.1m dish on thor 1w for the moment with tm1500ci ,Panasonic viera 42' plasma tv | Thanks for all the reply's. Is there much involved in setting up a 36 volt motor as ive just heard they are a lot sturdier than diseqc i have the budget to get the most suitable for the job. Many thanks. | ||
| | #6 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Two options: H-H mount 36V motor or Polar mount with actuator jack for larger dishes. If your receivers doesn't support 36V positioning then you will require a V box. The setting up principle is the same but more involved although personally not done a actuator/polar SM ![]() | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | There are still a few polar mounts available for the Triax TD, google for "Triax Polar Mount For TD Range"
| | #8 | ||
| Member Join Date: 16-02-2005 Location: Northern England
My System: Force T90, 1.2m Andrew, Triax TD64, Triax 17x6 Mutiswitch, Promax Prolink-4C Spectrum Analyser | Wouldn't go for a DiSEqC motor myself for that size dish in an exposed location. Try the Jaeger Supermount 99g or the Triax polar mount. | ||
| | #9 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | best would be to use the polar mount for the triax dish or if you've not bought the dish yet then take a look at a gibertini dish with polar mount there's not a lot in the set up of the polar mount just make sure pole is 100% level then set the polar mount elevation with an inclinometer/angle finder and then adjust the dish on the reference satellite which for your area as its ireland will be 5 or 8west depending on your longitude | ||
