Query- 2 dishes, 1 cable ?
Thread Tools Display Modes
Old 11-07-2008   #1
My System: SilverCrest SL 65
Question Query- 2 dishes, 1 cable ?
Hello
I was just wondering if anyone could help me out....
I'm trying to install a second dish but don't want to install a second cable.
Is it possible to run a small length of co-axial cable from both LNBs, and join them before they run on towards the decoder.
If anybody has completed a similar task, I would be extremely grateful for advice on the types of connectors to use?
The dishes are situated about 1 metre apart from each other, with a cable running about 10 metres to the decoder.
Many Thanks in advance for any help you can offer me.
Snaffles
snaffles is offline   Reply With Quote
Old 11-07-2008   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
If your receiver supports diseqc switching its dead easy - just fit a diseqc switch near the dishes and run the cables from the LNB's to the switch.
Get a 2 port switch, or if you have any intention of fitting more dishes get a 4 port.
__________________
Analogue forever!
Old 11-07-2008   #3
Question
It does suport diseqc switching, but I'm not permitted to go down that route for this particular situation.
What I really need is to run the signals from 2 seperate dishes down a single cable, and into a single set top box.
I was considering using a co-axial joiner, but I'm not sure whether this will work, or whether the signal will be lost in the "Spaghetti Junction" of cable and connections ?
Also, i'm hesitant to use the push in connectors.
Old 11-07-2008   #4
My System: DM70000s /Hdd/USB Nokia9311/Sattracker2.0N Philips175d MII Fun5
As far as I know, you only have two choices, use a disqec switch, or two cables with a tuner fro each.
But I don't understand how you could be forced not to use a switch when you could put a coax joiner on it.
And you are right to be dubious about push connectors, they are for cheepo old analogue systems, not for digital or satellite.
baxter_norway is offline   Reply With Quote
Old 11-07-2008   #5
rolfw's Avatar
A DiesqC switch sits outside where you want to join the cables, can't see what the problem would be. It uses "F" connectors which can be waterproofed, some switches like the global, have a waterproof cover.
__________________
Rolf
Donate
Old 11-07-2008   #6
Question
Feel free to correct me if i'm wrong here, but isn't a DiesqC switch just a motorised contraption which turns a single dish on a pole - so that it can face towards a different satellite ?
I appreciate that it might seem odd, but the layout of neighbouring buildings and an annoying telegraph pole means that there isn't one point where a single dish could be used on it's own to achieve a clear line of sight with both satellites.
If a DiesqC switch is a device which can switch between 2 dishes, then that sounds like the best solution, but I'm still relatively new to all this and would appreciate some clarification on this if possible.
Thanks again.
Old 11-07-2008   #7
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased...
The Sleepy Hollow pollracle has spoken!
Thanks again.
That's a motor, not a switch, the DiSEqC switch looks just like a splitter, but it does the opposite and allows the receiver to switch between the 2 dishes as long as it supports switching, which yours does...
__________________
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 11-07-2008   #8
rolfw's Avatar
Yes, it switches between two dishes, hence why I've recommended one. A DiseqC Motor is something altogether different.
Here are a couple from our supporting advertisers
http://shop.strato.com/epages/614638...witch%202/1%22
http://www.sateuropa.co.uk/product_o...d=12&subcat=57
__________________
Rolf
Donate
Old 11-07-2008   #9
Site administrator
No - A disecq switch allows two fixed dishes to be connected to one receiver down one cable.
Ive got a horribly complicated switching system in involving 5 dishes and 7 different lnbs connected to my DreamBox!
The picture shows a pretty typical 4 way switch.
__________________
Analogue forever!
Old 11-07-2008   #10
Talking
Hooooooo - ray !!!!!
This is indeed great news !
This seems like the perfect solution.
Thanks very much for all the help with this - gonna get me one of these gizmos tomorrow morning.
Sorry for my lack or understanding, but like the saying goes ... "A picture paints a thousand words."
Old 11-07-2008   #11
Lightbulb
By the way, can anybody tell me the correct pronunciation of "disecq" ?
Just don't want to look like a complete newbie in the hardware store.
Many thanks again.
Old 11-07-2008   #12
Robbo71's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m +Moteck motor.45E to 45W. 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Many thanks again.
I have always said DYESECK, but I may have been saying it wrong all this time.
The hardware stores I'm used to would not stock such an item, you may need to look up your nearest specialist satellite retailer.
Robbo71 is online now   Reply With Quote
Old 11-07-2008   #13
2cvbloke's Avatar
That's how I say it too, of course you could say Digital Satellite Equipment Control switch...
__________________
Old 12-07-2008   #14
Amo Amas Amant Admin
Topper's Avatar
Ermm
Well even that lot in my language equates to DIS ECK
If I wanted to Dyseck(t) something I would use scalpal or a sharp knife
Oh ok then who missed out on their tea??
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Topper is online now   Reply With Quote
Old 14-07-2008   #15
Thumbs up
Thanks VERY much again guys.
You've all been extremely helpful.
I've ordered a DiSEqC switch on e-bay, and am currently awaiting it's delivery.
I'll let you all know how it works out, once I've installed it.
Many thanks again.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
