do i need these on 1224 motor ? | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta |
just bolting up my 1224 motor and have 2 pieces that the manual doesn't refer to and wondering do i need to use them i've circled them in the below picture that i've found but they must be needed to set the dish declination angle ? as i will be using a 90cm andrews on the motor. also any one got some tips to setting it up ? thanks wod Last edited by wod; 12-07-2008 at 11:14 AM. | ||
| Super Moderator Join Date: 10-12-2004
![]() | I think you're right they are for getting the dish at the correct angle to follow the arc. Setting it up is very straight forward, plumb mount and align on your nearest due south satellite, etc. The only problem is getting the wires set correcly, as in the instructions it just states connect up the positive and negative connectors and move the dish East or West, if it moves in the wrong direction move it back to the starting position and swap the wires round. Do you have a 36v receiver or are you using a V Box? | ||
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta | yes i will be using a vbox with my receiver other pictures i have seen have these brackets on, i've been to local hardware shop to get some bolts as they was missing from the box. thanks for the replies | ||
