Eurobird 9 with Samsung dsr 9500Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 21-04-2008 Location: Uk
My System: Samsung dsr 9500 em via |
Hello I have a samsung dsr 9500 em via reciver currently pointed at Hotbird. Problem is I am trying to recieve channels on Eurobird 9. I think I need to reposition my dish in order to do this but the problem is I dont have a satellite called Eurobird 9 on my reciever. I cant add this satellite either. Can anyone help me plz thanks a lot | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You need to add a satellite in the satellite edit menu, you will then need to enter the transponder frequencies to the satellite, this site will give you the information you require: _http://www.lyngsat.com/eb9.html The you will need to swing your dish around to the West by 4 degrees and up very slightly. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just downloaded the manual and it appears that there isn't a way to add a satellite, so you will have to use one of the others, delete all of the transponders and add the new ones. I believe that you can do this with something like Setedit, which would speed it up somewhat. | ||
| The Following User Says Thank You to rolfw For This Useful Post: | dimenshion9150 (14-07-2008) |
| | #5 | ||
| Regular Member Join Date: 24-03-2008 Location: oxfordshire & banbury
My System: dr500 & dr5620 & humax5400z& sky&1.1triax& 1.35BlueStar | you can use EutelsatW1(10.0E). you will then need to enter the transponder frequencies to the satellite | ||
| 9500, dsr, eurobird, samsung |
