Set up Vendee coast, France, help pleaseInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 15-07-2008 Location: Jard sur mer, Vendee coast, france
My System: tried to set up in vendee coast, no success |
I bought a hd freeview sat receiver form Maplin, as they said it would work in France, but tried to set it up, using a sat finder meter, but could not get anything ! Sat must have been on holiday. I used a compass, to roughly set the angle at SE 28 degrees, then moved the dish up and down, no alteration in sat meter, tried altering side to side, but nothing either way ! Looked at tv picture , but nothing at all, whilst adjusting dish. Any suggestions as to what I am doing wrong, or can you not pick up the astra sat in that region, for british tv channels, or is there another system I can buy that will work in Jard sur Mer, vendee coast, France please ? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | What sized dish are you using? You should be able to pick up all of the channels with a 60cm dish, but you need to align the dish very accurately, most newbies also point the dish too high, your dish will probably have an offset of 23 degrees or so, so the dish face for that satellite will only be about 10 degrees off vertical. If you are getting no movement on the meter needle, you need to adjust the attenuation up or down and see if there is movement when you put your hand over the LNB, it should produce a blip. Check you connections http://www.satellites.co.uk/satellit...91-post14.html , as if they aren't made properly, the setup won't work. | ||
| | #3 | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | |||
| Member Join Date: 17-07-2005 Location: Plymouth UK
My System: Echostar 2110 Technomate 5200D Porty 2 S Crest SL65 1m H-H Lidl 80cm on TM2200 Lidl 40cm on Omnisat. |
Had no trouble finding Astra2 from JSM when we visit for "hols". Check there are no obstructions at 30 degrees elevation and use 160 degrees magnetic. Keep the compass away from metal e.g. car or dish as it can be "pulled". Make sure your receiver is set to a "live" channel. Shift the dish gently and slowly- give the receiver time to lock on. | ||
| coast, france, set, vendee |
