Setup help please | |
| | #26 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Looks very tidy indeed, compared to mine.
__________________ | ||
| The Following User Says Thank You to Robbo71 For This Useful Post: | Dogz11 (20-07-2008) |
| | #27 | ||
| Member Join Date: 01-07-2008 Location: Surrey, UK.
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | I do have a meter, and i'll give that a go along with the jubilee clip trick, i thought the receiver was good enough for that, when i finish work i'll have another bash. There's a small pitched roof below so its just a case of climbing out the bedroom window. | ||
| | #28 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | Some success... ![]() I have managed to locate Thor and from that i then found hotbird ! In case this helps others.... where i was going wrong The problems seem to originate from being 10 degrees out despite using a rangefinder compass. Subsequent difficulties arose from trying to rotate the 90cm dish and motor around the pole which was too heavy to move smoothly in conjunction with using the meter on the reciever. The solutions were the use of a jubilee clip which took the weight of the motor and made it easier and smoother to move around the pole and a using a PG753 meter (which needed some soldering before i could use it, which is why i was relying on the reciever meter, bad decision). I am still 10 degrees out and i dont really know how i was that far out with the compass. The motor reads approx 3 when i am at 13 degrees. But i'll leave it at that till the missus goes on holiday so she has her foreign TV till then. Once she's gone i'll have another bash to get it all perfect. In the meantime i dont think my reciever a Technomate 5400 usb is patched as promised from the dealer don't seem to have any channels other than the free to air, is there a quick check to see if its patched ?MANY THANKS TO ALL FOR YOUR HELP. I know i tried your patience, but i think i'm winning now and definitely wouldnt be without everyones input so Thanks again. ![]() | ||
| | #29 | ||
| Information Exec Join Date: 07-05-2007 Location: Midlands (UK) & Lanzarote (Canary Islands)
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | Visit the darkside and download 1. the loader, 2. the patch & 3. the latest softcam. SM ![]() | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | Dogz11 (20-07-2008) |
| | #30 | ||
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Yes, Press MENU>SYSTEM INFORMATION and look at the software version. Also on the same page if you have "CAS Menu" and "Biss Menu" it is patched. Pressing either of those takes you into "Key Edit" or "BISS" pages
| | #31 | |||
| Member Join Date: 09-07-2008 Location: Poland
My System: motorised 1.0m dish with crypitik V mount motor and Technomate 5400CI+ |
| | #32 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | A cheapo compass should give you an accurate enough guide to where due South is ![]() | ||
| | #33 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | Hi Peeps ...missus has cleared off ![]() I'm desperately trying to set this up properly....resetting the motor to the reference point. Then no matter how carefully i move it in either direction, using a meter i cant locate thor, i can locate 8 degrees / nilesat, but the damn thing will not locate thor, its either 8 degrees or astra ![]() once on 8 degrees i'm moving it really slowly about the pole but bugger all till astra kicks in any explanations please | ||
| | #34 | |||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Thor is the top of your arc so you will have to alter the dish elevation to get it
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #35 | |||
What you can do is send the dish to 8W, align on 8W, then send the dish to 0.8W using USALS and then tweek ![]() SM ![]() | |||
| | #37 | ||
You should be able to just flex it to find it, it is only slightly higher
| | #38 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | | ||
| | #39 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | Thats the problem then...slacken off the brackets and the weight of the dish and motor causes the setup to tilt groundwords compounding the problem.....ok thankyou...roofbound again ![]() | ||
| | #40 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | When it's on THOR, the dish wil be at it's highest point within the arc at your location ![]() | ||
| | #41 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | NO luck tonight...i'll have another bash tomorrow daytime. Cheers peeps i'll keep you posted. I'm not going to let this beat me. | ||
| | #42 | |||
I think you had better do a screenshot of the channels you can get and tell us what you think they are for the sats you can get post them here for confirmation. I am not convinced you are looking at the sats you think you are
| | #43 | |||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | ![]() | |||
| | #44 | ||
There are 11 satellites between the two and if you cannot hit one of them it must be your elevation
| | #45 | ||
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W | .........Although all this is shown in the guides being directed to ![]() | ||
| | #46 | |||
Magnetic pole variation means that you are quite close to the actual measurement if you had offset the compass As a first-order approximation, the Earth's magnetic field can be modelled as a simple dipole (like a bar magnet), tilted about 11° with respect to the Earth's rotation axis (which defines the Geographic North and South Poles) and centered at the Earth's centre
__________________ There is a very fine line between "hobby" and "mental illness" | |||
| | #47 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | O.K. bear with me... I have at the moment THOR and a strong signal 90+ percent on both level and signal. The transponder is 12643 V, 27500 KabelKiosk. Bit concerned that this really is Thor most other channels are incl BBC world service are bad signal. | ||
| | #48 | ||
| Super Moderator Join Date: 10-12-2004
![]() | There are a few Kabelkiosk I can find but they are on 8W, there are a few channels on 0.8W using 12643 V 27500 but they are part of Digi TV. Please check these 2 links and see if any of your channels match up: _http://www.lyngsat.com/8west.html _http://www.lyngsat.com/1west.html If not please try scanning the satellite you are currently on and post some more channel information. | ||
| | #49 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | yep i'm back at 8 west....booger when i change the sat (with the motor turned off) to 8west i pick up the following 10972 France 24 & cnbc-us 11011 cnn 1256 jaras | ||
| | #50 | ||
My System: Technomate 2200 motor, technomate 5400 ci +USB, 90cm dish... | GOT IT !!!!! Yessssss !!!!! at last.. 12607 digi 11403 lifestyle 11325 bbc 11166 gospel 11247 btv & vision norge thankyou, thankyou, thankyou..... roof bolts tighten quick | ||
