Top 4 satellite positons
Thread Tools Display Modes
Old 16-07-2008   #1
My System: TV: Panasonic 42PX60 DVD Recorder: Panasonic DMR EX85 AV Amp: Yamaha DSP Z9 Front Speakers: Monitor Audio GR60's Centre: Monitor Audio GR Centre Rear Speakers: 2 x Monitor Audio GR Centres Sub: BK Monolith DF [ No satelite equipment yet ]
Not sure if this is in the correct section but…
If you had to choose 4 satellite positions – what would you choose?
Currently I'm thinking of:
1. Hot Bird 6 at 13.0°E
2. Eurobird 1 & Astra 2A/2B/2C/2D at 28.2°E
3. Astra 3A at 23.5°E (have to choose this one due to my Slovakian wife)
4. Astra 1G at 19.2°E
At the moment I have chosen a fixed 1m Triax dish with 4 LNBs – will this affect reception quality (having 4 mounted)?
My installer keeps putting me off the motorised route
I would like to eventually tune in to Premier League broadcasts so I don't know if I have potential with the above locations?
kroc_kroc is offline   Reply With Quote
Old 16-07-2008   #2
wod
My System: triax td88 motorised, Vantage x221tsci, tms-1500ci, skystar 2, diablo v2.3, zone 2 minidish - setanta
well if the conax hack on 1west lasts a bit then 1west will be a good satellite position to have - thats if you have a diablo cam
16east for digitalb if you want premier league football, subscription card are reasonable price so an option to look in to
nothing wrong with a motorised dish if it is installed correctly, seems to me the installer is not or doesn't have any experience of them so is off putting you
but a 1.2m motorised dish would be a good option (only suggested 1.2m as you need 23east channels)
The Following User Says Thank You to wod For This Useful Post:
kroc_kroc (17-07-2008)
Old 17-07-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Well, the gain of the dish will be less at the offset positions,but with a large enough dish and strong enough satellites there won't be a problem.
You certainly shouldn't have problems with those 4 sats, apart from some transponders on 23.5E.
With the narrow LNBs you may also be able to fit one in for 16E, but you would need a Diseqc switch with more inputs.
Robbo71 is offline   Reply With Quote
The Following User Says Thank You to Robbo71 For This Useful Post:
Old 17-07-2008   #4
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Speak to your installer and specify motorised. If after this he is pushing you to go fixed multi-LNb route, I would find another installer. Chances are he won't be able to set up the fixed dish either
If you do go fixed with Multi LNb arrangement, The Triax 20 deg Triax bracket will be fine for the four satellites you mentioned. I would say align on 19e prime and offset 13e, 23e & 28e
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
The Following User Says Thank You to satelliteman For This Useful Post:
Old 17-07-2008   #5
Maybe it's because I want to install the motorised dish on the chimney breast? He says this will cause vibrations which may annoy the neighbors? Are the vibrations that bad?
Quote for fixed on chimney breast:
Triax 100cm dish
Triax multi LNB Holder
Triax 0.2db LNB x 4
4 way switch
Cable
£200
Labour
£100
Total
£300
Would the motorised route be a lot more expensive?
Was thinking of going for a Superior DarkMotor at £69.00 – a little pricey but I don't mind paying extra for peace of mind – installer has worried me about motors going wrong or being unstable in wind.
Is there any all in one kits which include the motor or is it better to buy the best dish, best LNB, best motor etc.
All the kit the installer is recommending is Triax but I'm not sure about these dishes after reading some reviews?
Old 17-07-2008   #6
Information Exec
It's a fair price but... a 1Mtr dish on a chimney may not be the best solution, maybe a TK installtion somewhere on the building. Vibrations, what's that, LOl
__________________
Old 17-07-2008   #7
Robbo71's Avatar
To be honest, I would not fancy a 1m dish on a chimney stack, the whole lot could come crashing down. Perhaps one of our installer members would be able to advise better.
Is this your only choice for installation location? I would have thought, just above the roofline would be a safer option if you have obstruction issues.
Cost wise the materials needed for a motorised dish and a mult-LNB dish are about the same.
Old 17-07-2008   #8
I think I want to go motorised. AFAIK there are no obstruction issues.
I live in a purpose built terrace flat (built 1910) so it's either somewhere on the front or the roof. I live on the first floor. I would have preferred to be more discreet with the dish.
What is a "TK installtion"?
Old 17-07-2008   #9
Information Exec
T&K: Two piece bracket arrangement, sizes extend from 12 inch to 36 inch fixed to the wall allowing a mast to be installed over and above the guttering height
Google T&K and all will be answered
__________________
Old 17-07-2008   #10
satelliteman – does your FRACARRO PENTA 85 pick up 23.5E in the Midlands?
Went to a friends house and he has this dish (lives near me) and he could get signals from 23.5E (with the FRACARRO dish) but didn't have the correct CAM to watch the channels (Skylink). The signal strength on most channels was about 90%. This dish to me looks good and some say acts like a 100cm dish. Would it be as good as the 100cm Triax?
Old 17-07-2008   #11
Information Exec
I get Astra 3 but lose it to rain fade. Your location is more East than me and will have more margin.
As for the PENTA being as good as a Triax 1.1m, I can't answer that as I have not compared the two against each other. One thing is for sure, it's performs better than a triax 88cm and will out perform some poor quaility 1 Mtr dishes
__________________
Old 17-07-2008   #12
Robbo71's Avatar
Now, if only someone would lend me their Penta, I could do some comparisons.
Old 17-07-2008   #13
Information Exec
I have one in stock here. Your welcome to come up to visit Robbo Only problem is, you might have to come out and help with my installs for the day
Personally, think the Triax 110 would perform as good as or slightly better than the PENTA 85
__________________
Old 17-07-2008   #14
Robbo71's Avatar
I would be happy to When can I come?
Old 17-07-2008   #15
wod
1metre dish on the chimney thats is not recommended as it will come down in windy weather
better would be an install on a wall using suitable brackets such as t&k brackets
also @ 23east there is astra 1e which is very strong signal , are the channels you need to have on there or astra 3a check _www.lyngsat.com
Old 17-07-2008   #16
Information Exec
yes Skylink packages are on both sats 1e & 3. My guess would be Astra3
__________________
Old 17-07-2008   #17
The Skylink package that my wife will use is on Astra 3a.
The chimney would be good because it would be much more discreet but I guess we'll have to go for the front of the house I don't mind it but I hope the neighbors don't complain.
To make matters even worse the place where I'm getting it from only has 110mm Triax dishes in stock. They can get 100mm but I want it installed on Sunday and I'm too impatient to wait. I guess 110mm equals better reception from satellites but not so good reception from neighbors.
Is the t&k bracket with pole a better/stronger route than the mount which I think is called an arm mount?
I think this motor says that it's suitable for up to 1m dishes – is the 1.1m pushing it too much?
And I'm going to go for a STAB Motor – I think it's the HH100. It's £70 and i know it's supposed to be slower than the others but apparently they're quite sturdy and reliable.
Old 17-07-2008   #18
Information Exec
Don't put a Triax 110 with motor using the standard L type arm, you will lose it to the wind for sure Go for the T&K and pole option
Re: The neighbours, run them a feed and keep them sweet, Lol
Sorry had to,
I wouldn't put a 110cm on a DiSEqC motor esp.. on T&K high up, others may have different views. 1 Mtr yes !
The STAB motor is good, no noise but very slow unlike the Moteck
__________________
Old 18-07-2008   #19
Just found out the new installer is recommending the STAB HH100 motor with the 1.1 dish. I told him my concerns i.e. it's designed for 1m+ dishes but he assured me he has been doing it this way for years and hasn't had any problems.
The dish would be mounted just below midway up the house (between groundfloor and first floor windows).
Old 18-07-2008   #20
Information Exec
That's fair and many will have different opinions. In fact I looked at doing just that but decided against it. I would recommend the use of heavy duty bracketry for such a job.
Don't forget to post the final installation pictures up on the members own systems section, look forward to it.
good luck
Satman
__________________
kroc_kroc (18-07-2008)
Old 18-07-2008   #21
Robbo71's Avatar
I have a Triax TD110, and it is actually only 100cm wide, so really a 1m, not a 1.1m.
I have it on a STAB H-H 90, it turns OK, but the main problem seems to be slightly more freeplay than is ideal. I'm waiting for the motor to die before I buy a better one though!
Old 18-07-2008   #22
rolfw's Avatar
This seems to be an inherent fault with Stab motors, far too much play for my liking.
__________________
Rolf
Donate
Old 18-07-2008   #23
What would be a safer bet then in terms of motor for that size dish and location? What's the next step up from DiSEqC? I'd rather be safe than sorry.
I don't want to be calling the installer out every week with alignment issues etc as I'm not very technical – maybe that's his plan?
Old 19-07-2008   #24
Information Exec
OK, Horizon to Horizon 36V motor such as the Jaeger or you can use a polar mount and 36V jack arm/actuator with positioner for the Triax 1.1,
but........I would personally recommend the following as I have used and installed many and seem to be reliable:
> Moteck SG2100a / TM2200
> Good Quality 1 Metre Dish, maybe a Gibertini as an example.
__________________
kroc_kroc (19-07-2008)
Old 19-07-2008   #25
So when can you come down and install it then
I'm going to try and push for the 1m Gibertini then – I've always liked the look of these. I'm just worried about the delivery of the item. I live in London and I'm worried that the dish will get battered in transit. I wouldn't mind paying a bit extra and collecting from a local shop – but don't think there's anyone who stock them locally. Seems to be all Orbital and Triax around here.
