Which lnb for my dish?
Thread Tools Display Modes
Old 20-07-2008   #1
My System: technomate 5200 no dish or moter yet
I am trying to set up a system (on the cheap!) for the very first time. I have a TM 5200 USB, and a Fortec star HH90 motor from Maplins. My problem is I have scrounged a dish off my brother he wasnt using. Its old but in excellent nick. It is 90 cm wide and has Fuba Sat witten on the dish. The bracket that holds the LNB has a small aperture of only 2.8 cm or 11/8 inches in old money. I have bought a lnb from my local Maplins but its too fat for the dish bracket. Is there such a thing as a slim lnb that would fit my small bracket?
Secondly I have set a scaffold pole (vertically true!!) into the the ground at the top of the garden, with the wifes permission!! and will mount the dish on the pole. It is about 65 metres from my TM 5200. For this dist do I need special cable or will any do?
Thanks in hope of your help
sreser is offline   Reply With Quote
Old 20-07-2008   #2
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus, FRACARRO PENTA 85, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W
Welcome to satellites,
You might be able to purchase a new LNb holder for your dish with a 40mm collar OR change the dish
65Mtrs of quality coaxial cable will have a loss of 20dB @ 2150Mhz (top of 'IF' band). You can install line pre-amp to compensate for such loss.
Example: Technically, we measure satellite signals in dBuV.
A 90cm dish on a strong satellite will receive approx 80dBuV. You will loose about 2dB through the motor and 2dB through connections.
80dB - 20 - 2 - 2 = 56dBuV
A receiver requires 52dB minimum so the conclusion is to fit a pre-amp esp... for weaker satellites.
Other good signal parameters are required for acceptable viewing like carrier to Noise and Bit Error ratio but for cable loss we looking at signal power dB
Just check Power Consumption of the receiver as it has to supply the motor, LNb and a pre-amp.
Benchmarked cabling such as wf100 is fine
Lots of info here
Satman
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
Old 20-07-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Yes I think you are going to need a "Universal Offset feedhorn" and a C120 LNB. It doesn't work out very cheap though.I think I would try and bodge something first, by making/finding a new holder. You may be able to buy a single holder online from somewhere, or try a 1"1/2 plumbing waste pipe clip.
Another option apart from an amplifier, would be to use better specified cable, such as wf165, the attenuation for this is only 20.9dB per 100 metre compared to 32.5 for wf100.
Following on from satmans calcs:-
80-13.5-2 -2 =62.5 dBuV, a bit more of a margin for you.
Or in other words, the attenuation of 65m of wf100 is approx equal to 40m of wf100, which you should be able to get away with.
Robbo
Robbo71 is offline   Reply With Quote
Old 21-07-2008   #4
thanx guys you have given me some great ideas. I will have a bash and let you know
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
